    Results 1 to 9 of 9
      Would Air Ride Four link framework hurt or help overall frame stability
      The air ride system looks like it could give some extra frame to frame reinforcement. Are there other concerns that this four link system would present for my convertible. Or do the benifits outweigh any problems?
      I am only looking at rear system,,,not the front. I plan on standard Global West with coil overs in front.
      I plan to drive this car on weekends, to shows and i am looking at some sort of 400 HP 383 as a motor.
      Calicraig
      67 Camaro SS Convertible
      Frame off project started September 2005
      Had a 69 Z28 clone back in the 80's
      Still kicking myself for getting rid of it
      Portland OR
      The primary area of torsional flex in a convert is between the cowl and the rear frame rails. The first gen convertibles are incredibly flimsy in this area, hence the "cocktail shakers" in the four corners of the vehicle to damp the cowl shake. An AirBar won't help this, since it doesn't do anything to reinforce the primary area of weakness. IMO, you want to get some good subframe connectors - Global West, or DSE. They really make a difference in how tight the car feels.
      Orange 69 Camaro RS, DSE, Baer, LS7/T56, driven!
      Jul 2003
      Anaheim Hills, CA
      I agree.. on a vert I would try and tie the frames together. But I don't see how the rear air bar system would hurt stiffness and we know they do reduce weight..
      1968 Track Rat Camaro:
      Nov 2004
      Colorado
      Quote Originally Posted by Steve1968LS2
      The total of all the tubing and brackets is less than a pair of leaf springs? Can't be by much then.
      Feb 2006
      South West... Viva la New Mexico!
      pt is right. The four bar out back and the connecting bridge will help stiffen the rear laterally and cross load but the biggest cause of flex on that car is going to be the front sub frame. Get that fixed up with connectors or a new clip and add what you want to the rear and you are going to be good to go.
      I forgot about the subframe connectors
      I definitely had those in mind,,,The DSE's look like a nice option.
      I hadn't considered the weight savings. So it sounds like it gets a general approval rating????
      Calicraig
      Nov 2004
      NW Arkansas
      Quote Originally Posted by EFI69Cam
      leaf are very heavy especially if they are multi leafs there are only 3 added brakets and the biggest one is sprung weight. the air springs are light as well
      KENNY DAVIS HOTRODS
      Portland OR
      Quote Originally Posted by calicraig
      IMO, if you're not trying to get the nth degree of performance on AutoX or track days (and if you are, you need to do more on the front suspension first), the AirBar is likely to be a choice you'll be very happy with. Just don't forget about those frame connectors.
      Quote Originally Posted by PTAddict
      Yea, I want it to be capable in the occasional twisty,,,safe at least when I may want to challenge some 5.0 on a Saturday afternoon. But mostly it will see more show time than romp time. Thanks for the input.
      Calicraig
