Thread: Replacing all rear sheet metal?
02-14-2006 #1
New to Pro-Touring
- Jun 2005
- 33
I'm going to get started on my camaro project soon and I had some questions. I plan to replace about everything on the rear of the car except the frame rails. How should I go about doing something like this? Is there a order I should do it in that would insure the best fit and correct alignment? Any tips on this would be great. Oh yeah, I will be using all goodmark parts other than using the DSE mini tubs.
Mike
02-14-2006 #2First align the doors and leave them on the car during the process. Do quarter panel, inner and outer wheelhouse one side at a time. Also make sure the rear glass and trunk
lines up at various times during the surgury. Also take your time welding and moving from one spot to another, so not to distort the metal. Good luck.
02-15-2006 #3Make sure you set ups some reinforcement jigs because when you start removing panels the body becomes weak. You can use square tubing or angle iron. Just about anything so that when you remove panels, there is still something there holding the car in place. Later you just cut the jig off. If you only do one panel at a time you will be safe. An example would be if you just do the passenger quarter and leave the driver quarter on until the pass side is welded up. Then you can go to the driver quarter. That also leaves other panels in place for you to line up with as a guide. Have fun and take lots of pics. Try to avoid warping the metal if you can.
02-15-2006 #4
- Nov 2004
- Colorado
- 1,260
