Results 1 to 10 of 10
Late F body (LS1) rear disc on 1st gen F body
So far so good. I had a 9" axle built for my 69 Camaro. It is fitted with the late 4th gen F body disc. We transplanted the outer hub portion INCLUDING the e-brake/drum configuration. I cut down and welded the ebrake cable mount to the lower rear leaf spring mount. It is a perfect fit. The ebrake cable then loops up over the spring and around BACK TO THE ORIGINAL 69 ebrake cable mounts on the frame rail. I am thrilled with how well that worked for super low dollars.
Just wanted to give you guys the 411 on that incase you came across a late 4th gen axle and were not sure if you could get the ebrake portion working (note, the earlier models had the ebrake built into the caliper).
Chris McDonald
