Results 1 to 17 of 17
Thread: pro touring truck?
02-01-2006 #1
- Oct 2004
- 90
pro touring truck?
Hi there I have been a lurker on here for quite a while. I have been looking for a mid '60's mustang but have put that on hold for the time being.
I do have a '79 f100 short box. Its a bare bones good starter truck right now. what do you think of a pro-touring truck? My only problem is lack of suspension for the front. I can get lowered I-beams from a couple of different places or fatmans makes a MII cross member for it. I will eventually run a stroked 302 and a 5 spd.
I used to race a '77 demo truck (circle track) and we liked the twin I-beam for strength. We could pull lap times faster than the demo cars with a comparable motor!
Does anyone got some pics for quick reference? I see lots of chev trucks but no fords thats one of my main reasons for going this route.
02-01-2006 #2I think it's a cool idea. I'm a fellow ford truck owner that's going the route you are.. I've been told the I-beam suspension isn't so hot for handling, but I want the Belltech I-beams and I'm going to do a flip kit on the rear for now. Trucks can look just as mean as cars, in my opinion.. with enough work I'm sure it could perform comparibly. I've got a 5 spd and a 302.. I want to swap in a 351 eventually and turbo it (down the road) next winter it will get AFR heads/Cam/Intake, though.
Here's a pic;
That batman symbol will be gone as soon as I get it out of storage. Previous owner put it on, heh. I've got the new one sitting here along with my other goodies.:3gears:
90' F150 - 302 V8, 5 Spd, 275s on all corners.
02-01-2006 #3
- Oct 2004
- 90
nice truck. Ya the I-beam has no camber or caster adjustment which sucks. If you get a full eurothane bushing set it really tightens them up. Your better off than I am I have a 300 six and a 3 on the tree right now! No PS or PB its about the most basic truck I have ever seen. But with what I want to do to it I figured no reason to spend $$$ on items I will be removing or changing.
02-01-2006 #4
- May 2005
- St. Augustine, FL
- 1,529
I am just starting a new project soon and it is a truck. It is a newer truck but it will be a street fighter and be all business with no frills. Mine will be a very cheap build that should teach me alot.
Andrew Petty
02-01-2006 #5I am pretty lucky. I pretty much bought a semi-complete truck. I'm only 18, and recently at that. The steering isn't as tight as I wish it could be and I've been told I won't be able to get a rack and pinion for it.. But hey, at least you can build the motor right the first time and not have to pull out a decent one. (Like I will eventually, maybe I'll just blow it up first.
Originally Posted by chet
I'm getting those I-beams, better coils, and the flip kit.. the front was raised two inches by the last owner with BB coils apparently. To "match" the rear. It looks decent but I like the low and aggressive look. I don't think I'll be able to squeeze the tires I have now if I drop the front and rear 5 inches. The front tires already rub on full lock on the control arm.
Is there any control arms that would transfer over?:3gears:
02-01-2006 #6
