    Results 1 to 17 of 17
      Aug 2003
      Prescott Valley, AZ
      LS1 specific cooling
      Will any radiator work in a LS1 swap or do I have to get a crossflow?
      It's shake and bake!!! and i helped!
      Drewco Homes
      Red Deer, Alberta, Canada
      Stock rad works fine.
      -Matt
      Matt
      Instagram: Cst_koon
      Jul 2003
      Anaheim Hills, CA
      Any will work.. there are some packaging advantages to having both inlets on the right.. many guys make them that way at no additional cost.
      Whats your budget?
      1968 Track Rat Camaro:
      Aug 2003
      Prescott Valley, AZ
      mine<yours
      Drewco Homes
      Jul 2003
      Anaheim Hills, CA
      Ha! .. I doubt that..
      Oh, if you look at a stock 4th gen f-body radiator you will see it's nothing fancy.. in fact you could use one just fine (with the fans). You just have to rig up a mounting system.
      Aug 2003
      Prescott Valley, AZ
      nah, i already have my big block setup with a howe radiator and dual fans - it will work perfectly.
      Drewco Homes
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by harshman
      nah, i already have my big block setup with a howe radiator and duel fans - it will work perfectly.
      If cooled the big block then it will cool the LSx motor
      the hard part is running the upper radiator hose since it has to go from the far passengers side on the LSx to the far drivers side of the radiator.
      Did you use temp sensors to run the fans? If so what temp? the LSx motors like a specific range to run thier best in.. too cool is bad for performance.
      Aug 2003
      Prescott Valley, AZ
      Dual temp controls. I've been penciling out the costs of installing a gen one 500 hp small block vs. 500 hp Lsx and I have seen the light. While I may throw in an additional $1k the fuel and weight savings plus the reliability of it will exceed it in every way.
      Drewco Homes
      Los Altos CA
      Hey another convert!!!
      glad to see you saw the light
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by ilovefirstgens
      Amen brother!!
      We have a new member of the lsx club
      Mountain View, CA
      I'd like to see your math on this if you don't mind sharing.
      True T.
      My blog
      Aug 2003
      Prescott Valley, AZ
      Quote Originally Posted by Damn True
      pm'd ya
      Drewco Homes
      Apr 2003
      Nyköping, Sweden
      Country Flag: Sweden
      Steve, do you have any part numbers for the temp sensors for the radiator?
      Jan
      Jan Suhr
      Nyköping, Sweden
      1969 Pro touring Camaro Z/28 LS1/T56
      Scandinavian Pro Touring Forum protouring.se
      Burnaby, BC, Canada
      Quote Originally Posted by jannes_z-28
      Jan
      Jan, I have an extra set from my Ron Davis setup that I won't be using. You can have them for free if you like.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Apr 2003
      Nyköping, Sweden
      Thank you, I have sent you a PM
      Jan
      Jan Suhr
      Nyköping, Sweden
      pm'd ya
      Will you you also send me the figures?
      Ontario, Canada
      Quote Originally Posted by Steve1968LS2
      A dual pass rad. Been thinking of using one in my Vega ( if I ever get that far ). The only thing that concerns me is the possibility of too much pressure build-up in the inlet tank. A dual pass effectively reduces the number of core tubes by half and doubles the length of the core tubes. Has anybody here used one before?
      Ken
      My other car is a Vega.
