    Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
    Results 81 to 100 of 184
    1. #81
      Los Angeles
      What do pickup truck manufactures do to prevent cargo from ripping into the passenger compartment. I have had way more then 150lbs worth of stuff in the back of my silverado.
      Is there a special structure to the design of a trucks sheetmetal that could be replicated while building a firewall to prevent this issue?
      I know that there are 10's of millions of pickups out there, so I am going to ASSume that the manufactures have figured something out, but then again I have been wrong before.
    2. #82
      Dec 2003
      lost
      Pick-up trucks don't come factory equipped with all the junk people haul around. You are responsible for making sure the stuff in the back is properly secured and won't become a projectile in the event of an accident (in fact you will be responsible for any damage due to improperly secured cargo).
    3. #83
      Mountain View, CA
      What is the point of a fuel cell? It's safer than a standard tank. People install them to make their car safer (there are people that put them in for style, but they're dorks) It's stupid to argue about this. If you have the opportunity to make something safer there is little reason not to do it and it's bloody irresponsible to advise someone against doing it.
      Integrating the support structure of the cell into the chassis of the car makes the system safer. No reason not to do it.
      Unless you want to be less safe, but I don't think Scogin is looking to be less safe or he wouldn't be installing a cell.
      True T.
      My blog
    4. #84
      Jul 2003
      Anaheim Hills, CA
      I could have sworn I posted in this thread.. am I loosing my mind??
      1968 Track Rat Camaro:
    5. #85
      Newbury Park, CA
      Impact protection, from hitting something and being hit, is the primary function. The stock tank straps are sufficient for anything that tire traction can throw at it.
      A friend of mine has a Fuelsafe tank that was custom made to fit into the stock location, has a stock shape (tapered rearward), and has internal baffling and pump. The shell is aluminum with a nicely manufactured bladder. The tank is filled through an access door in the trunk, hence the stock filler neck is not used. The filler neck is the weak link in 67-8 F-body tank, though I have not heard of many burned cars.
      Around $1400.
    6. #86
      Mountain View, CA
      Quote Originally Posted by Steve1968LS2
      I think you'd chimed in on Harshman's fuel cell thread.
      True T.
      My blog
    7. #87
      Aug 2003
      Prescott Valley, AZ
      does anyone have a pic of Big Red's tank?
      It's shake and bake!!! and i helped!
      Drewco Homes
    8. #88
      Jul 2002
      Muskegon, MI
      Quote Originally Posted by Rick Dorion
      And then there's the stock tanks which, to me, are a 'pinto problem'. I'd like to add a cell for safety reasons. Has anyone added protective bars around a stock tank to make it more crash resistant? Don't mean to take this thread in a different direction but am interested in gas tank safety.
      Woops sorry Rick I misread the "around stock tank" part. I have a fuel cell.
      I am about to do this to my car using 1 5/8" tube like roll bar material. My rear bumpers will be tied together to an entire structure I am going to build to protect the fuel cell and the rear of the car in an accident. Since we all know the rear of these cars are terrible in rear end collisions. Virtually no strenght at all back there.
    9. #89
      Jun 2006
      Katy,TX
      Fuel Cells plumbing and accessories
      OK guys some input here please. Since the TA is getting switched from a drag car to more cornering teh 79 Camaro is getting switched to a drag car with a rool bar so we can go faster and not be in triuble and be safer. After spinning one night hard with a 1.5 60 ft car you really need a rool bar!
      Since sumping a new tank is as much or more than a fuel cell I bought a 10 gallon aluminum one from Summit(good clearance sale now!) to put in the trunk. I want to add a fuel level sensor, but will have to pull the foam to drill it. I assume not a big deal.
      I HATE gas smell in the car, plus the safety issues but figure the cell in the trunk is the easiest. Elevate it so even the sump is in the trunk-otherwise there has to be suppoer underneath it per NHRA. So wil run the fule lines throught the trunk.
      I have seen vents with coiled hard line, coiled SS braid, or just the roll over vent fitting on them. I would guess venting it out the trunk. Iknow my circle track buddies even put a filter on it so trash, wasp nests can't get in the vent.
      What is the best fill cap? Curently it has a plastic lever type. Switch to a metal lever type, screw type. 45 degree fill neck?
      Any thoughts or pictures?
    10. #90
      Jun 2006
      Katy,TX
      Surely some of you have fuel cell pictures.
    11. #91
      East Coast Florida
      Skip -
      It's a matter of choice. RCI, Fuel Safe, Summit all make remote filler necks, etc. The one thing you have to remember about having a cell in the trunk (and this also addresses your smell issue) is that NHRA rules require you to have the trunk sealed off from the passenger compartment. You do this by welding in sheet steel or aluminum behind the rear seat. This needs to be sealed all the way around.
      Anyway, just some thoughts.
      Project "Freebird"
    12. #92
      Jun 2006
      Katy,TX
      After the roll bar goes in it'll be sealed. just want some opinion of pros and cons of various fillers and vents people have found.
    13. #93
      CT
      Lets see pics of fuel cells in the OEm location
      Self explanatory,I am not interested in a fuel cell in the trunk.
      john
    14. #94
    15. #95
      Farmington Hills, MI
      That is exactly what I want to do. Where can you buy a fuel call like that?
      Jeff
      JEFF SHORTT
      -IDEAL STEEL
    16. #96
      DeWitt, IA
      Quote Originally Posted by GBodyGMachine
      Jeff
      ATL and Fuel Safe.
    17. #97
      Nov 2004
      Country Flag: Netherlands
      I took off almost all the red paint (still have to do 1 side) because I'm going to have it powdercaoted. It's a 32gal ATL cell.
    18. #98
      This is how I did mine.
      Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
    19. #99
      From yalls experience, what is the best size to use and fits the location?
      Jared
    20. #100
      Jun 2002
      Benicia, CA
      I took a 20-gallon RCI aluminum fuel cell and dropped it through the trunk. The fuel cell containment box sticks up into the trunk anout 3 inches at the most, and below the trunk a few inches more than the stock tank did. I am going to cover it with an aluminum lid. Will still be able to fill through the license plate fill location.
      http://new.photos.yahoo.com/[email protected]/7
      http://new.photos.yahoo.com/[email protected]/0
      http://new.photos.yahoo.com/[email protected]/1
      http://new.photos.yahoo.com/[email protected]/5
      http://new.photos.yahoo.com/[email protected]/2
      Jeff
      1971 RS Camaro: PAINKILLER
