Results 1 to 20 of 184
Thread: Fuel Cell Super Thread
- Aug 2004
- San Antonio, Tx
- 1,193
i was thinking everyother exit
, well i was looking at either the 18 gal. or 22 gal. tank. also when you use fuel safe's level sending unit i'm using auto meters gauges doesn that matter?
Instagram: CamaroAJ
04-27-2005 #2Personally, for a streetable car, I'd go as big as possible. It's the same amount of money to fill, just in bigger (but further spaced) chunks.
Full, the 22 gallon tank will only weigh roughly 25lbs more than the 18 gallon...not enough to worry about, all other things being equal.
The Fuel Safe sender comes in the 0-90 ohm flavor unless you specify otherwise, and I'm not sure what other choices they have.
Doesn't matter what brand gauge you have (even stock), as long as the ohm range is correct. If you bought a gauge for a GM car, you have the 0-90 ohm gauge.-Matt
