    Results 1 to 20 of 31
      Scottsdale AZ
      69 Camaro C4/C5/LSI/brake coversion help needed!
      I have a 69 Camaro with drum/drum brakes and I am looking for an inexpensive ($500-$600) front big brake upgrade.
      I am interested in a C4/C5/ or LS1 upgrade but I don't know what to look for.
      Which one is the best for the money and easiest to do out of C4/C5/LS1?
      What size rotor? I have seen C4/C5 in several sizes ie. 12", 12,5", 13".
      Can I run a stock booster/master cylinder?
      Does anyone have a breakdown of the parts needed?
      Please help!!!!
      Steve
      Vail, Arizona
      It may be difficult to do any of those for that price using new parts but maybe. I would suggest looking at www.touring-classics.com They have all the work done for you but it will cost a little more than 5-6 but its worth the headaches you will save if you ask me. Best of luck!
      Walla Walla, WA
      This has been discussed many times. A search will get you a lot of information. To summarize, you can get LS1/C5 calipers (and used rotors) from Ebay for as little as $100. Mounting brackets are available here for about $135:
      http://www.speedtech-performance.com...o%20brakes.htm
      Replacement rotors, if needed, can be purchased at any auto parts store for about $75 or less each. You can use Earl's braided steel brake hoses for a '69 Camaro with the C5/LS1 calipers. You'll need to get your current hubs turned down to fit inside the rotors, there's information on the Speed Tech site. The hubs may also need to be faced, as the rotors index off the hub faces.
      The LS1/C5 rotors are about 12.7" in diameter, hence the various claimed sizes.
      I run an S-10 MC, but you may well be able to use the stock MC/booster.
      Again, try a search and you'll get lots of information.
      Newbury Park, CA
      If money is the limiting factor, then the choice will be determined by your rim size.
      C5 won't work in a 16" rim, and may not fit in some 17's without some rim spacers. C4's will work in some 16's and most all 17's.
      Scottsdale AZ
      What are the disadvantages to C4?
      There is a set for sale in the Classified section for $325.
      https://www.pro-touring.com/forum_main.htm
      Anyone see anything wrong with them?
      Scottsdale AZ
      Also, is the 12" rotor to small?
      Scottsdale AZ
      I have been looking on ebay to buy the parts (rotor and calipers), but I am still unsure what to look for.
      C5/C4/LS1?
      I don't have wheels yet, so I am open.
      It sounds like C5 on the front is the way to go. Is that the deal?
      C5 on back too, or I see LS1s on the rear most of the time. Does the C5 not work on a stock rear?
      Any guidence would be appreciated. I would love to hear from someone who has done a budget large brake upgrade.
      Steve
      Scottsdale AZ
      I am still confused. See questions above.
      1. Standard C5 12" or 13"?
      2. Will C5 work on the rear?
      Scottsdale AZ
      What should I look for when buying parts to do the coversion front and rear?
      Celina, Texas
      I resonate the idea of contacting Touring-Classics
      As a matter of fact, you'll see that they are site sponsors. Maybe see if you can purchase partial kits, ie brackets only, etc.
      Scottsdale AZ
      I would love to purchase them, but I have a budget of $800 front and rear.
      Nov 2000
      O-town
      Steve, I will call you tomorrow, I think I can help you, Steve
      Scottsdale AZ
      Would something like this work for a street driver?
      http://cgi.ebay.com/ebaymotors/88-96...QQcmdZViewItem
      C4 13" front
      C4 12" rear
      Get myself C4 front calipers and brackets
      and LS1 rear calipers.
      May 2002
      Southeastern WI
      I have a pair of LS1 rear calipers for sale too.
      Jeff
      Scottsdale AZ
      What size rotor do they use 12"? What else what I need t set them up?
      Nov 2004
      Dallas Texas
      98-02 LSI Fbody frt discs
      i carry 1/4" steel lasercut brakets to mount the LS1 f-body calipers cradles,rotors , this gives you a 12x1.25" rotor a large dual piston aluminum caliper for good stopping power and this setup should be doable for 3-400$ max your drum spindles and hubs need some minor machine work , and longer wheel studs are needed also a adapter fitting to combine the oe bubble flare and inverted flare hard lines . 50$ shipped lower 48 states on brackets
      Scottsdale AZ
      You say body calipers and rotors.
      What about C4 and C5? Also what diamenter rotors?
      Houston, Tx
      Quote Originally Posted by zman1969
      Do your brackets come with instructions and/or parts lists?
      I am VERY interested.
      Scottsdale AZ
      Are C5 and LS1 front calipers the same?
      Should I focus on 12" C4 to keep from any wheel troubles?
      Nov 2000
      O-town
      No there not, C5 say "CORVETTE" on the caliper, LS1's are plain,
      Focus on how you want to build it, if you have to a 12" rotor that sfine it going to stop better than 69 factory parts,
