    Results 1 to 7 of 7
      May 2001
      Mesa, Az.
      Roll Cage building help
      Does anyone have a suggestion about the easiest way to build templates for my roll cage? I had a buddy tell me to get some thick copper wire and use it to mark the outside radius of my bends. Any other suggestions? Thanks Phillip
      Mountain View, CA
      That's the way Stielow does his. Seems like a good idea to me.
      True T.
      My blog
      You can use conduit and a conduit bender to prototype a cage.
      jp
      John Parsons
      May 2001
      Mesa, Az.
      That is another good idea. Thank you. Phillip
      Mar 2004
      Mid-Michigan
      Alstons has an excellant worksheet you can download. This is what I use. The instructions make the layout portion very straight-forward.
      Here is a link...
      http://www.cachassisworks.com/cac_worksheets.html
      Also many of the tubing bender suppliers have excellant instructions and guidelines for laying out and bending tubing. JD Squared or Pro Tools, check them out also.
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      May 2001
      Mesa, Az.
      I haven't picked up my bender yet so maybe my question will be answered then... but why do they use a 13 5/8 diameter circle? Is this the diamater taht their bender will do? ~Phillip
      Oakdale,CA
      Tube layout
      Hey Phil, There are all kinds of tricky tools and sheets, I even have software that will do this ,but the down and dirty, works all the time deal is this.........I use a full size piece of cardboard or full size layout on floor when we do a new cage, measure the widths at the floor,center of B pillar by your shoulders and then at the roof of the B pillar, sometimes it help to use a prebent piece of tube out of your bender to get this upper dim. Then measure up from your floor plates to the center of the bends and leave a bit extra on the ends@3" to final cut in place. then look at the Die you will be using...mine in 1.625 is a 5.5 inch.......you can then use this info for the bends or again grab your dummy bend and make your curves in your template.........remember only the outside dim is important @ meaning the main hoop needs to clear the inside of your body and panels. Important!!!! is think through were you need to start your bend to have your centers line up where you wanted............Email me if you need any more info or picts....Rhys FCRacing
