Results 1 to 15 of 15
01-19-2006 #1
- Nov 2004
- Suwanee, GA 30024
- 52
Market Research for Affordable Subframe
What kind of suspension would you like to see? (ie..C4, C5, C6)
What kind of steering? (ie..Mustang 2, modified)
What kind of pricing?
01-19-2006 #2My uneducated impressions:
C4: Just too old. It was a good design, but the C5 is better. I don't think component pricing is going to be much different, so just go C5.
C5: See above.
C6: Is this out? I haven't paid attention. I thought we were still on C5.
Steering: Why not stay with the C5 pieces? (Size, perhaps?) I think a rack-and-pinion setup is best, so if it can be done it should. It might not be possible (rephrase that to mean "at a reasonable cost") so a recirculating-ball box may have to be used. If so, check to see if there are changes that can be made to improve the geometry.
Pricing: Sell me the tenth one at $100, complete. (I don't want the first ones, since there are usually teething problems with new products.) Since I have no idea of the work or material cost involved I would say that you could make money selling them for $2500 with suspension. Of course this does not take into account the engineering work and other business expenses, so it just goes to show I don't know what I'm talking about. (Case in point, Wayne Due's IRS kit for the Camaro: $700 for a few pieces of metal. When I first looked at the kit I thought it was an outrageous price. For $700 I expect him to install it, too. But then I paid a little more attention: 14 bends, 17 weld joints, 22 holes, as far as I can tell. Even if the parts are machine cut and machine bent and welding jigs are set up there are a few hours of shop time involved. If the big dollar equipment is not being used then this could take a week to cut, machine and weld the parts.)
I would want it set up for coil-overs or air bags for a second-gen Camaro and it should allow 275/40/17 tires. (Make it handle 315s and you will probably have something nobody else does, yet.)
01-28-2006 #3
- Nov 2004
- Suwanee, GA 30024
- 52
With all the engineering involved. There is no way a complete unit can be sold for $2500 including suspension. Using the C5 components is the way to go for now, since you can fit a 275 tire (possibly a 315). Considering the pricing for other bare subframes,the $2500 - $3000 range is possible. All engineering and design will continue, since the 5th one is done.
03-02-2006 #4What's Up Dog ???
Tray ,,Got any pictures of the progress ?Look,s like you haven't made a choice on the front suspension ?? What kind of progres have you made ?? I made a gear change to 3:73, tore engine down, it's still down waiting on parts,,, Finally found what was making noise,, Bent Rod #8 cyl.. it was driving Me crazy,,,, Roger J
03-03-2006 #5
- Nov 2004
- Suwanee, GA 30024
- 52
Roger, Some friends and I are currently on a quest to build an affordable C5 subframe. I am currently working a full c-5 front frame for my car. Any luck on getting a Dana 44 yet? I may have to get with Neil on some of the front points later one. Things are moving slow, but they are moving.......Tray
03-04-2006 #6
