    Thread: Offset?
      Colorado
      Offset?
      Could somebody explain wheel offset to me. I thought it was the deviation from center. Such as an 8" wheel with no offset would have 4" backspacing. Recently at Disco Tire, they told me that the 8" wheel I was looking at had zero offset and 4.5" backspacing. Now I am confused.
      Thanks, Brett
      Oct 2003
      Arvada, Co
      You are correct in both accounts. Confused even more? Wheel width is measured from the tire bead surface to tire bead surface. Backspacing is measured from the wheel lip which happens to be around .5" out from the bead surface. That is where the extra bit comes from.
      Brian
      Nov 2001
      Sacramento Ca
      up in the top of the forum under "wheel tech questions" is the following link.
      it describes in great detail every thing you wanna know
      check it out.
      how to measure offset, backspacing, etc.
      good stuff in there. should answer all your questions.
      Tony Langlois
      1966 Corvair Monza
      Colorado
      Thanks for the help, it is all clear as mud now.
      Brett
      Tomball, TX
      Wow, I didn't know that. Good thing somone brought that up since I'll be doing all my BS/offset measurements over spring break.
      Ryan
      '68 Camaro (slowly coming back together...very slowly)
