      Sep 2014
      Need help with insurance valuation
      I am close to driving this and working any issues out before it gets bodywork and paint. I’m mostly looking for a finished value but as is value could be helpful. When I insure it about all that needs to be done is the interior, seat covers in progress from legendary, new top, body and paint. I’ll just add my copy paste list of things done. I’ll probably miss a few things. I haven’t seen similar build and condition Cutlass cars for sale. Chevelles yes, but they bring more money. I’ve tried the Olds forum and facebook page with no love. They shun ls guys. Links to any similar cars for sale or sold would be very helpful.
      Axles tapped for 1/2” threaded studs
      18” wheels
      C6 corvette brakes
      Front Kore3 brackets
      Rear 2002 Camaro backing plates
      Custom NiCop brake lines
      Wilwood brake proportioning valve
      Tanks Inc tank for fuel injection
      Custom designed and cut fuel pump spacer
      Walbro 450 e85 compatible fuel pump
      Vibrant -6 PTFE fuel lines
      Vibrant -6 fittings
      GM flex fuel sensor for e85
      Jeep Grand Cherokee power steering box
      Dorman power steering pulley from Pontiac G6
      All new polyurethane suspension bushings, except two which are rubber
      All new body mount bushings
      All new steering parts
      New shocks
      Chevelle front sway bar with poly bushings
      1979 Trans-Am rear sway bar with poly bushings
      Champion radiator for manual car
      Champaign dual electric fans with shroud
      Auto AC Solutions AC condenser
      Shiftworks shifter adapter for 4L80e transmission
      Engine is a 2010 Silverado 6.0 short block with TBSS intake, cam and truck accessories.
      Holley mounts, oil pan, transmission crossmember used
      Ceramic coated headers
      Dual exhaust with Spintech 3000 mufflers
      Factory e38 ecu and t42 transmission controller
      4L80 transmission rebuilt to handle 700hp
      Circle-D 3200 torque converter
      Tuned with HP Tuners for e85
      BP Automotive engine harness
      Door hinges rebuilt
      Changed rear to limited slip and .373 gears
      Lowered 2”
      Frame had a few mount holes repaired and was powder coated. Checked out square
      Floor had a couple patches as well as the trunk
      Floor painted top and bottom
      Firewall painted
      Engine and accessory brackets all painted
      Wheel well liners painted
      Small area under passenger door weatherstrip rusted out was rebuilt
      Car will be painted original Viking blue maybe with some metallic.
      Re-doing seat foam, covers and plastic from legendary. Covers are about 6 weeks out.
      Dec 2011
      Oregon coast
      Hagerty now has "Vehicle under construction coverage." might be your best bet talking to them and see what they say. Like you said not many comps, but Olds, Buick and Pontiac always take a significant hit compared to chevy for what is essentially the same car. Looking at bring a trailer similar Cutlass convertibles with fairly stock restorations start in the low $30s. With all the upgrades plus the LS swap your probably looking at mid to high $30k to low $40k range assuming it's all done well. If it were a 442 convertible or a Chevelle convertible the sky is the limit, but when it comes to the big money the trim tag matters.
      also depending on what insurance, you are going to use, until paint and body work are done a lot of insurance companies will not want to insure it for much regardless of all you hard work because most of their valuation is based on photos. Make sure you have all your receipts in order and organized so you can provide that to your insurer to show your investment.
      Sep 2014
      Thank you, that is helpful.
      Dec 2011
      I agree, this needs a construction policy. As it sits, this car would be hard to value anywhere near what you've actually put in it.
      The list you provided is extensive and I think you've got a good mix of parts in there, but most of it is stuff the car has to have.
      The transmission for instance. That's a nice piece that's been built, but in the car's current state, it's basically useless for adding any amount of value.
      This is a car that is undergoing a mechanical restoration with OEM+ level parts, and a body/interior that looks to need a decent amount of work. It's harsh, but in my opinion, this car is not yet valued on the sum of it's parts. It's worth more in pieces than it is together.
      When the body work, paint and interior is complete, this could easily be a car that sits nicely around 40K. Maybe higher to the right buyer, but right now It's probably worth 10-15K as it sits. If your plan is to drive the car to enjoy it while you're completing those other pieces, you'll likely have to do so under the knowledge that it's likely not possible to insure the car for what you have in it and you could take a bath if something happens.
      Sep 2014
      Thanks for your thoughts on this
      Beach Park IL
      Here's my hot take.
      It doesn't matter what it's worth to anyone else. Insure it for the value it has to you.
      Donny
