    Results 1 to 9 of 9
      Jan 2026
      Spring Rate On My Daily?
      Hi. I'm new here. This is my First Post. I know nothing about suspensions (or about of anything else if you exclude tequila), and I have always considered suspension tuning a "dark art" that is best left to the experts. But I'm a car (and motorcycle) guy, and I hate to let anyone touch my car, even if it is just a beat-up daily driver. So, I'm here to learn about suspension and see if I can maybe upgrade what I have.
      My question for today is this: Does anyone here happen to know what the spring rate is on stock springs (front and rear) on a 2013 Honda Fit Base Model with manual transmission? I am unable to find this information on the Internet. It may be marked on the spring itself, but I did not see it the last time I had the wheels off.
      Thanks.
      Aug 2022
      SoCal
      You'll find better answers here:
      https://www.fitfreak.net/forums/
      Jan 2026
      Thanks, Doc. Been there for ten years. Posted my question there several days ago. 38 Views, 0 Replies.
      Aug 2022
      SoCal
      Quote Originally Posted by Marrk View Post
      Maybe try a search first. I'm seeing quite a few threads about that very question:
      https://www.google.com/search?q=fit+...&dpr=1.5&aic=0
      Next options are Reddit and/or Facebook groups dedicated to the platform.
      You are very likely the first person to ever ask a question about a Honda Fit on this forum. If you're not getting answers on a dedicated forum, you're unlikely to get them on this one.
      Jan 2026
      Thank you, sir. Duly noted
      One last question: Spring rates are marked on the parts themselves, correct? If so, then mine should be marked somewhere. I'll just have to find it. Unless it was a label, and the label fell off.
      Thanks, again.
      Jul 2008
      Look up autocross or SCCA groups in your area on Facebook. Someone they're might be able to help, if not know someone with a set of scales so you can corner measure your car and have a better starting point for spring rates.
      *Jeff*
      Jan 2026
      Quote Originally Posted by Hotwire View Post
      Thank you. That's good advice. The Fit is often used in autocross.
      Feb 2013
      South Carolina
      I am very good with the interwebs:
      For a 2013 Honda Fit (GE8) on stock suspension, all trims use essentially the same stock spring rates, and the best available measured data says:
      Front spring rate: ≈ 1.7 kg/mm ≈ 95 lb/in
      Rear spring rate: ≈ 2.0 kg/mm ≈ 112 lb/in
      These numbers come from owners who’ve had the OE springs measured or back–calculated them; Honda doesn’t publish spring rates in the service manual. A FitFreak thread cites 95 lb/in front, 112 lb/in rear for 2009+ Fit (GE8), which includes the 2013 model year.
      So for your 2013 Fit base manual, you can safely work with:
      Front: ~1.7 kg/mm (95 lb/in)
      Rear: ~2.0 kg/mm (112 lb/in)
      Jan 2026
      Quote Originally Posted by JustJohn View Post
      Thank you, John. I will make note of those numbers.
