Results 1 to 3 of 3
Thread: Holley Terminator X wire port
Hey there,
I'm in the middle of a build on my 51 Chevy Pickup and working on body work/fabrication. I plan on running Holley's Term X wire harness, and so I know I need to go through the firewall.
My question is, how big a hole do I need to have to pass it all through? Also, what are some of you using for a port to run it through that looks good and functions well?
Also, if you could share where you placed the port in relation to the engine so I can get ideas.
Thanks,
Glenn
Glenn
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy Silverado
My last project....
07-29-2025 #2
- Dec 2018
- 34
On my 67 Ford Fairlane I have the Terminator X wiring coming out dead center of the firewall right behind the engine. I used a ron Francis ga50 oval grommet made for fox body mustangs because my firewall has a oval knockout the same size where factory AC lines would have exited. I want to say the id of the grommet is about 1 or 1 1/8".
I have the ECU mounted above the right kick panel and had plenty of wiring available.
07-29-2025 #3
