Thread: 1971 Camaro Project
04-03-2025 #1
- May 2023
- 23
1971 Camaro Project
1971 Camaro project available as-is or as a custom build to your specifications.
📍 Located in Vicksburg, MI
Key Features & Components:
- Chassis & Suspension:
- Detroit Speed (DSE) Quadra Link rear suspension with JRi canister coilovers
- DSE C6 Floater Kit
- Extreme Front Subframe with JRi canister coilovers
- DSE Minitubs & Subframe Connectors installed
- Powertrain & Drivetrain:
- 416 LT1 Engine
- T56 Transmission
- Custom Rick’s Aluminum Gas Tank (set up for vaporworks)
- Baer 6S Brakes
- Ididit Steering Column
- Interior & Electronics:
- American Autowire Classic Update Kit
- Dakota Digital Custom HDX Gauges
- Dakota Digital Cruise Control & AC Control
- CustomWorks RS Grille & Dash Insert
- Exterior & Cooling:
- Ringbrothers Hood Hinges & Door Hinges
- C&R 15-11054 Radiator
- Smoothed Firewall with Peterson Dry Sump Tank mounted in the passenger-side cowl
- Additional Custom Work:
- Custom Dutchboys Chromoly Roll Cage
- Raised Transmission Tunnel
There are many additional parts included with the project.
💰 Price is $75,000, depending on included parts.
📞 For details, call or text Jason at 269-823-2967.
04-03-2025 #2how are you going to avoid bump steer with the sweet rack and pinion? I wanted to run one but they typically only run 18" center to center which is quite a bit shorter than what is stock on that car? I wanted to run one but my center to center (70 mustang) was 24.5" so I need to find another solution. From looking at the pictures, your pivot point on the steering arm is pretty far inward from the pivot point on the intersection between the lower and upper control arm mounts. You may want to weld an extension on the rack to move the pivot point closer to the A-arm mounts. In it's current configuraton, it looks like you are going to have excessive bump steer. Those sweet units are the cats ass though. Nice piece.
04-03-2025 #3
