      Feb 2013
      South Carolina
      Need some help wiring ignition to Terminator system
      Still wiring the car and made it to the FI harness. Mostly all is well but I'm stumped on getting the ignition hooked up.
      It's all Holley stuff on a BBC:
      Dual sync distributor
      Hyperspark 2 ignition box
      Hyperspark coil
      The distributor connector was obvious enough but there's the points trigger wire on the diagram going to a random spot and it looks like I'll need to source a few terminals and seals to go with the connectors. If anyone has sketched this out before or can help me out I would appreciate it.
      Is this what you need? I have used this a few times to do what you are describing with a hyperspark distributor.
      https://www.efisystempro.com/holley-...arness-term2hs
      Feb 2013
      South Carolina
      Nope, the distributor is already plug n play. I thought everything else was too.
      I called in to Holley this morning and maybe have it straightened out. Basically finished the regular rewiring of the car this weekend and my brain shorted out when I laid out the ignition components.
      Feb 2013
      South Carolina
      I actually got some follow up info from Holley later on from the same tech support person. There was a harness pigtail included with the ignition box and immediately made everything make sense.
      I think I was just tired of staring at wires at the end of Sunday.
