      Dec 2013
      Howell Engineering LT4 harness not working
      Hi guys. Got an issue with a harness I purchased form my LT4 swap.
      I called howell engineering and told them what I was building. LT4/4l80e swap into a 56' pickup.
      The guy there said no problem, we'll build you a harness and ecu for your application. You'll just need to get a stand alone TCM.
      Fast forward to this month. We got everything installed and the engine has about 25% power. Got a tuner involved and he logged into the ECU and said it's in limp mode and it looks like it's due to no VSS sensor signal.
      Call Howell and they say " gee..yeah, not really sure what's happening as we've never built one for a SC application". So now i'm paying a couple guys to try and do their R/D to find a work around. Needless to say i'm pissed, I would have never bought this crap if I had known I was the guinea pig.
      Anyone ever run across this issue doing this swap. Did you find a VSS work around or figure out how to properly pin in an old 2 wire VSS instead of a 3 wire?
      Thanks for any help
      Mountain Springs, Texas
      I am not sure if your case is the same but I have used this with good results. Sorry if I misunderstood.
      https://www.amazon.com/Michigan-Moto...OUK533GU&gQT=1
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Dec 2013
      Thanks. I don't think so though. It has to go from the new style 3 wire VSS that was mated to the LT4 (like the 6l90e) and back to the 2 wire for the 4l80 :(
      Pretty sure I used it to convert a two wire VSS sender to connect to an ECM looking for a three wire signal. It has been a while though.
      Nov 2018
      How about a 3 wire VSS for the 4L80E? The description says it's for using a 4L80E (amongst others) behind an LT1. You'll definitely want to discuss it with them before buying.
      https://bp-automotive.com/product/t5...al-3-wire-vss/
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Apr 2018
      Possibly this: https://sirhclabs.com/product/cortex...ensor-adapter/
      but of course not in stock. But I do have one.
      Dec 2013
      Thank you guys. We seem to have found a schematic and pinned a connector in there after figuring out what ground it wanted to see.
      Now on to the next issue lol
