    Results 61 to 75 of 75
    1. #61
      Feb 2013
      [QUOTE=Aussie;1401390]
      Quote Originally Posted by Josh@ridetech View Post
      Hi Josh, just asked as ajs1luv refers to his 68 Camaro vert
      He was asking about Subframe connectors. The one's that we build do not fit a convertible car due to floor bracing in different locations than a hard top car. The subframe itself will work just fine.
      Quote Originally Posted by C Presley View Post
      Josh, which headers work best with the ridetech Subframe? Ultimate Header's, Speed Engineering? Are there other brands that are compatible? Please advise.
      For an LS, the Ultimate's fit the best by far.
      We have also fit up Speed Engineering but I have seen some the consistency vary a little on those and took some taps with a hammer. The Hooker Blackheart's are a no-go, the second tube on the driver's side occupies the same place as the steering shaft does. I'm positive there are other longtubes that fit but there are so many options now it's hard to try them all. A mid-length is also an option as they're all more of a "swept back" design.
      Ridetech Suspsension
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    2. #62
      Oakl;and, Ca
      Unfortunately I have blackheart headers on my ls3 68 camaro
      now! ��
      Also i purchased the subframe connecters and I have convertible �� Josh we need to talk!
    3. #63
      Feb 2013
      Quote Originally Posted by ajs1luv View Post
      now! ��
      The headers could potentially be modified, however, it'd be easier to change to a set that fits (Ultimate, a mid length set, etc).
      The subframe connectors on a convertible are will not work. If you bought them through a dealer of ours, you can set up a return with them and get your money back as long as they're new in the box. Our dealers should know they don't fit (it's also notated on the website).
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    4. #64
      Oakl;and, Ca
      [QUOTE=Josh@ridetech;1401625]The headers could potentially be modified, however, it'd be easier to change to a set that fits (Ultimate, a mid length set, etc).
      The subframe connectors on a convertible are will not work. If you bought them through a dealer of ours, you can set up a return with them and get your money back as long as they're new in the box. Our dealers should know they don't fit (it's also notated on the website).[/QUOJosh, what headers are you using with your subframe? Can you enclude names and part numbers. I have some Ls blackhearts for sale as well!
    5. #65
      Oakl;and, Ca
      Josh, can you list the Ls headers (with part #) that will work with your subframe. Thanks! I
    6. #66
      Feb 2013
      As of today, these are the part numbers that I know will work for LS and SBC engines:
      LS engine:
      Ultimate Headers (longtube) 102121
      Speed Engineering (longtube) 25-1027
      Small Block Chevy:
      Flowtech (mid length) 31108FLT
      Flowtech (longtube) 11100FLT
      Hedman (longtube) 68270
      Hooker (longtube) 2451HKR
      As we validate more fitments, I'll try to keep you all updated.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    7. #67
      St Augustine FL
      What modifications would have to be made to use a stock style z-bar set up?
      Is it even feasible?
      Mike M
      67 Camaro, big plans, empty wallet!!
    8. #68
      St Augustine FL
      Mike M
    9. #69
      Feb 2013
      Quote Originally Posted by Carver67 View Post
      Sorry, didn't see that question pop up.
      No modifications needed. We have our own bracket for cars wanting to reuse the z-bar.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    10. #70
      St Augustine FL
      No worries.
      Thanks for the confirmation. I appreciate these great new products.
      Keep it up.
      mike
      Mike M
    11. #71
      Oakl;and, Ca
      Josh, will there ever be optional upgraded billet aluminum spindle offered for this subframe?
    12. #72
      Feb 2013
      At the moment, we don't have any in the works but we're always looking at things we can do/upgrade. I wouldn't write that option off, it could be a thing in the future.
      Tech Specialist
      Phone: 812.481.4734
      Project Fox
      1979 Trans Am
    13. #73
      Nov 2025
      Please consider offering a C7 brake option for the upright. Too few do these days.
    14. #74
      Nov 2025
      Quote Originally Posted by 69RSLT1 View Post
      Actually, now that I look at it, the brake bracket appears to be modular, and could potentially be replaced with a bracket drilled for C7 caliper. The only question would be if there is sufficient clearance at the OD of the spindle center section to use the C7 caliper. The C7 caliper mounts closer to the centerline of the hub.
    15. #75
      Oakl;and, Ca
      Josh, will the engine sit lower than stock subframe height, with the ridetech subframe? If so, how much lower?
