      tool to remove windows
      Can anyone recommend a tool (where to purchase) to remove front and rear windows from 69?
      Any of the "Taiwan" tools guys at any show or local tool store will have a tool for removing windshields. About $8.00 for the Taiwan version.
      Mike
      www.musclecardeals.com
      NY
      Try this from Eastwood. Well worth it. http://www.eastwoodco.com/shopping/p...ord=windsheild
      The needs of the many outweigh the needs of the few.
      Oct 2005
      Odessa mo.
      They also make a serrated wire for cutting them out this usually works a little easier. Most body and paint supply stores sell it. But it's also requires 2 people.
      [QUOTE=toxicz28]Try this from Eastwood. Well worth it. http://www.eastwoodco.com/shopping/p...ord=windsheild[/QUOTEe]
      I saw that one. Looked like it was hard to fish through the window, but if you say it works good I will give it a try.
      Thanks.
      Tulsa, OK
      [QUOTE=FJB2069]
      Quote Originally Posted by toxicz28
      Thanks.
      I have used it with good results, you may be able to find one at your local paint shop if you don't want to wait for shipping. Just remember to not put pressure on the glass, rather toward the metal of the car than the glass if you run into a tough area. The windshield will be tougher than the rear window.
      1980 Z/28 383, Vortec heads, 2004R 342.1 powertrac
      1971 Firebird on rotisserie
      2006 Dodge Daytona Charger
      "Torred" # 1988 of 2000
      2013 Hot Wheels Edition 2 SS Camaro
      "I'm Not a Gynecologist, but I'll Take a Look"
      Aug 2003
      .035 Mig wire is all we use. DO NOT try the special tool on the windsheild, you WILL most likely break it. The rear window is temped, a hammer wont hurt it unless you swing the hell out of it, but the laminated 35 year old front is delicate at best. Cut a piece of wire 3' long, Just tie the wire arond a screwdriver in a twisting and knoting pattern, then find a spot you can slip it through the budle. Tie that end to another screwdriver. Then pull the 2 ends and work it around the glass.
      Thanks for the info.
      Fred
