Thread: Master Cylinder Bore Size
02-26-2024 #1
- Jun 2022
- 3
Which master cylinder bore size should I get with a 2.75 caliper bore, 6:1 pedal ratio, manual front disc/9.5 drum rear? Wilwood has been giving me advice ranging from 1-1-1/8. They can’t seem to understand that stock these cars have a brake pedal stop for a manual setup. They keep trying to get me to order a compact master with a built in pushrod which isn’t needed. I thought 1” was for a stock manual drum and 1-1/8” was for power disc. Wasn’t sure if 7/8” would be good with the caliper piston size being that it’s on the larger side according to Wilwood. But according to the internet a stock piston is around 2.9”. I know 7/8” would be softer but will increase the pedal travel compared to a 1”. I’d rather have a softer pedal to be honest. Thanks.
