    Thread: LT4 in a 56 GMC
      Dec 2013
      LT4 in a 56 GMC
      Hi guys, doing an LT4 in a 56 GMC. She has a 76 Camaro subframe on it.
      My questions are do I need a conversion oil pan to make it fit?
      Should I convert to wet sump pan?
      And depending on answers, what motor mounts, oil pan and auto trans would you pair this with?
      Thank you much!
      Feb 2020
      If the motor is a dry sump, it will fit without issue with the stock pan.
      I just put one in my 75 camaro.
      You may want adjustable mounts to push the motor as far back as possible though, or you will need to change the bolt to drain the oil as it will be incredibly hard to change otherwise.
