      Apr 2004
      Cedar Rapids, IA
      Need education on LT1, LS1, LS6...
      can someone please educate me on the years and diffrences between these engines and any that I left out.
      Walla Walla, WA
      Quote Originally Posted by rohrt
      I'd strongly urge you to do searches on the appropriate sites, including www.ls1tech.com
      mo
      lt-1 93-97 basic 350 reverse flow heads,ls-1/ls-6 97 to now new motor everything.nothing interchanges with the old
      Dunwoody, GA
      you need more info than can really be provided here in a decent manner. www.camaroz28.com, www.ls1lt1tech.com, www.ls1tech.com, www.lt1tech.com, and for the 92-93 cars try www.speeddensity.org check them out and youll find anything you need to know on those boards.
      the LT1 started in the vette in 92 and went to 96. for the camaro/firebird it was 93-97. the 92 and 93 cars are batch fire injector cars not sequential fuel injection. the 92-93 cars are also speed density not Mass Air Flow cars. however all LT1s can be tuned MAFless and run MAFless. the LS cars can too but i honestly havent looked into that at all. the 92/93 cars are also Eproms not Flash Prom PCM. that means they need a chip to be tuned. this is just a simple over view though. check outt hose websites for the info you need.
      oh and its completely minor but the only things that interchange between the LT and LS motors are lifters and spark plugs. haha pretty lame i know, but i do find it funny that everything was changed including the lifters however the lifters will interchange.
      Trey
      ~ Jon Hammond
      Hey you can interchange the rods too.... at least a LS1 can use a SBC rod.
      Bret
      Bauer Racing Engines
      Specializing in late model GM motors
      1964 GTO (work in progress for 13 years)
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Not gettin done anytime soon
      2000 Camaro SS SCCA FS Car
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
      Jun 2002
      Long Island, NY
      LT1 is a completely different animal
      This thread will tell you everything you need to know about LS1s (some 4th gen info as well):
      http://www.ls1tech.com/forums/showthread.php?t=213148
      Taken directly from the thread:
      Differences: 98,99,00,01,02
      This is some basic info on the LS1 that i've gather from all of the internet and put into one list:
      1998
      1. Had differnet casting heads which had perimeter bolts and valve covers.
      2. Ignition coils were mounted to the valve covers one at a time.
      3. The water temp gauge actually works.
      4. 98's do have an oil life monitor, they just don't tell you anything when its time for a change. You can find it in Auto-Tap
      5. WS6s had single outlet exhaust (all others had duals)
      6. Steering wheel controls were completely different part with indentations on the buttons, and were better built
      7. Only year that Purple, Gold, and Green were available
      8. Some very early Trans Ams came with LT1 style headrests
      9. Rear hatch release was poorly designed and often caused problems releasing mechanism
      10. Early model 98 Monsoon stereos didnt have capability to control 12-disc CD changer
      11. 1998-1999 automatic transmission LS1s could be started in 1st gear even with the shifter in 2nd. Starting 2000, if you put the shifter in 2, it would start off in 2, even from a stop.
      12. 1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT faster than 2000+ cars
      13. 1998 cars had 28 lb fuel injectors from the factory
      14. 1998-2000 cars had a larger cam than the 01-02 cars
      15. 1998-1999 cars had more restrictive exhaust manifolds
      16. 1998-2000 cars had an LS1 intake with EGR
      17. 1998 and some early 1999 cars had blue outside rear view mirrors (TA/Formula only)
      18. 1998 only LS1 blocks had a much smaller cylinder sleeve that only tolerated a .005" hone
      19. Last year F-body to use the old 15.5 gallon steel fuel tank.
      20. Only year LS1 F-body to contain a gascap with a tether long enough to actually hang from the fuel door while open
      21. Only year LS1 F-body to not contain the famous GM black box used in the event of an accident to record up to 5 seconds of pre-crash data
      22. 1998 only cars had a different PCV system with the PCV valve located above the passenger side valve cover
      23. 1998 most cars did not have an idle adjustment screw on the throttle body. Some 98 cars do have the idle throttle stop set screws.
      24. 1998 cars have a completely different PCM from 99+ cars
      25. A production shortage of F-body cams caused the use of a C5 cam to be installed in F-body LS1s for a very short time
      26. 97-98 LS1's used a paper water pump gasket. The only gasket that isn't reuseable
      27. SSs did not ALL go to SLP starting in 98. Y2Y was the RPO code that sent them to SLP for additional options
      28. SS option did not "include" the Synthetic oil package, it was a SLP only Option
      1999
      1. 1999-2000 cars switched to 26 lb fuel injectors
      2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
      3. Redesigned cylinder sleeves that allowed for a small bore, up from .005" in 1998 models.
      4. Midyear model change to a cheaper steering wheel audio control button without finger indentations, and cheaper built
      5. 1999 cars continued the LS1 intake with EGR provisions
      6. 1999 cars continued more restrictive exhaust manifolds and larger cam
      7. Only year that Hugger Orange was available (Camaro only)
      8. 30th Anniversary Trans Am available with special blue and white paint package and blue clear coated WS6 wheels
      9. Switch to larger 16.8 gallon plastic fuel tank to meet new emissions requirements.
      10. Gascap tether was shorter and could no longer be used to hang on the gas door when open.
      11. Company wide change added black boxes to record up to 5 seconds of data before a crash
      12. Rear hatch release was redesigned with stiffer spring that released the hatch better
      13. Water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
      14. An oil life monitor was added to all LS1s, thus changing the gauge cluster a little to show the oil life reset swtich
      15. 1999-02 cars had a different PCV system with the valve located to the side of the intake manifold
      16. Early production 1999 Trans Ams still had the blue outside mirrors, but a midyear change went to the non-tinted ones
      17. 1999 there was the color "Medium Blue Metallic" which was available on both the Camaros and Firebirds. Only one year of that color
      2000
      1. Redesigned exhaust manifolds for new emissions standard actually flowed better and created a little more HP.
      2. 2000 continued use of LS1 Intake, EGR, smaller cam, and 26 lb fuel injectors
      3. Added rear child seat safety hooks to interior per federal requirements
      4. Very early run of WS6s had "salad shooter" style rims. A production change switched back to standard 5-spoke WS6 rims.
      5. Camaros got redesigned 10-spoke base rims, and SSs came with new 10-spoke rim design
      6. First year of Monterey Maple Metallic paint
      7. Charcoal (grayish) interior was replaced with Ebony (almost black) leather interior
      8. Cloth interior cars got new rainbow colored cloth patterns
      9. Camaros only got the Pontiac steering wheel with optional audio controls
      10. Throttle body cam was increased in size to slow the speed at which the car reaches WOT
      11. Automatic transmission cars were reprogrammed to allow a car to start off in 2nd gear from a stop when the shift lever is put into 2.
      12. The last year a WS6 Formula was offered
      13. Starting 2000 intake lids contained a seperate breather filter
      14. 2000+ Camaros came with body colored mirrors instead of black ones like 98-99
      2001
      1. A small percentage of 2001 and 2002 LS1s actually had LS6 blocks which had a different part number and a darker metal cast
      2. Starting 2001, all LS1s came with an LS6 intake manifold without an EGR system
      3. Advertised HP output was changed from 305 to 310 on base LS1s and from 320 to 325 on WS6s and SSs
      4. 2001-02 cars have a smaller cam from the Vortec truck engines to increase low end torque
      5. 2001-02 cars had 28 lb fuel injectors like the 98 cars (albeit different part numbers)
      6. WS6 cars had a redesigned 5 spoke rim which was more wavy
      7. WS6 cars got less suspension upgrades from a base Trans Am suspension than previous years
      8. Manual transmission cars all came with the Z06 clutch
      2002 - Last year of the F-body
      1. 35th Annivesary edition of the Camaro, and Collectors Edition Trans Am available
      2. 2002 LS1 head gaskets redesigned. The new ones are a pressed metal, as opposed to the graphite ones and are no longer specific to the side of the car theyre installed on
      3. 2002 cars continued with the LS6 intake, 28 lb fuel inectors and smaller truck cam
      4. 2002 continued the use of an LS6 block in some LS1 F-bodies
      5. A factory supported optional 345 HP option could be ordered from SLP
      6. Manual transmission cars continued use of the Z06 clutch
      7. Some 2002 model F-bodies came with a revised rear view mirror that had the map light buttons on the bottom, rather than the front.
      compiled by constrictor98ta (mike) from ls2.com
