01-11-2006 #1
- Jan 2005
- Houston, TX
- 143
Battery in Truck-Grounding an LS2
I am getting ready to put an LS2 in my 1969 Camaro. I am trying to get everything ready while I wait for the motor to be built and the KB blower (if they ever release it).
I keep read how important it is to ground the engine properly. My battery is in the trunk. The ground cable comes out of the trunk and bolts to the frame by the gas tank. In the engine bay, I had planned on running a ground for the frame to the motor and the body. If it helps, the rear frame and front sub-frame are connected with subframe connectors.
Somewhere I read that I need to run a cable from the battery to the motor directly. Is that really necessary?
Thanks.
Phillip
