    Results 1 to 14 of 14
      69 Chevelle Cage
      Im sure this has been beat into the ground over and over, but I am gonna ask anyway. I am looking into putting a 10 point in my chevelle, and am trying to explore all options possible.
      I know that a cage from scratch will fit much better, and look cleaner, but damn I hate building them. So here I am, hoping you can toss me some ideas on where to find pre-fab, or box kits. Anything would be great..
      No help? anyone? just some ideas?
      westchester county new york
      Merk If you jump around a little in the forum there are a few threads about cages.
      Go to cscracing.com for a ton of info and prices on cages.
      May 2002
      Northern California
      not sure where you are located but you can buy a kit and have it welded or find a shop that will bend one up from scratch...looks alot better IMHO
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Nov 2002
      Georgetown,TX
      Where are you located,MERK?
      Z, im outside Leander Tx, just north of Austin. Guess I should get off my lazy arse and fill all that stuff in so ppl wont have to ask.
      I found some box kits, one from Summit, and the other for S&W. Anyone have any other ideas, or know of any shop around my area, or hell in central TX, I could look into?
      mo
      i would just have someone build one,box kits dont fit and look like crap.check around houston area,i've seen some race car builders around there.
      Jan 2003
      Arizona
      Or do both. The S&W 6 point kit might make a good starting point if you feel the money spent is worth saving you a few bends. But yeah, nothing fits like custom.
      ________________
      Steve Chryssos
      St. Louis, MO
      Too bad you're about 20 hours away ;) Let me know if you need something bent. I've never installed an S&W but I've heard they're decent.
      Scott Rhea
      It's not what you build,
      it's how you build it.
      www.izzyscustomcages.com
      Speed
      Done many Chevelle cages? I looked at your site, and you work looks awesome, with alot more options than I have been seeing. I have been asking around my area and not having a whole lot of luck. I do go up to your area once or twice a yr, shoot me a couple prices, (base+1, and base+2)maybe we can work something out...
      Rockford Illinois
      I'm with Steevo, I wish I had started with an S&W kit and made the reat custom. The S&W kit has easier welding points because of the front halo wrapping around and the uprights mounting on the bottom of the tube. It also makes it fit farther forward toward the windsheild keeping it more out of your view if you are a taller person. Price for a kit is also usually a bit less and the time it helps save from making a mistake and the cost of tube these days makes them a real value all around.
      Jim Nilsen
      May 2000
      Speed Raycer. Check your PM's.
      St. Louis, MO
      MERK... sorry, I don't get back here as much as I'd like to anymore. Shoot me an email through my site....
      Scott Rhea
