- Jul 2023
- 3
67 Camaro C6/Z06 brakes Help Backspacing
Hello!
I've searched the forums up and down and am trying to square away the backspacing I need for the custom wheels I'm planning to purchase. I have pretty good idea of what I think I need but want some help from other who have more experience. I'm a total amateur who's been reading these forums for years and can usually figure stuff out. But I'm just scared in getting the wheel offset wrong when spending $5k on a set of custom rims.
Specs:
67 Camaro
Front:
ridetech upper/lower control arms
ridetech Coilovers
C6/Z06 Brakes 14 in Rotor
AFX spindles
Rear:
Will be installing Ridetech 4 link
Currently have lowering Hotchki leaf springs
NOT tubbed and does not have rolled fender lips
10 bolt rear end
I need help in determining the correct offset so I don't rub or hit my fender wells with it being lowered. For the front wheel with the C6/Z06 brakes it needs 1.7 inches from the mounting surface to clear the calipers. My goal is to get the wheels tucked in enough to avoid any worry of hitting my fender lips. I think I know what I need for the rear, but will take any advice!
I'm thinking minimum 5inch offset for the front, but wondering if I need to go in more? If do 5in offset and have the wheel built to fit the brakes I won't need the 1 inch spacer. So this combo will bring in the wheel 1.5 inches. The pics currently have Boss 338 with a 4.5 inch offset and 1inc spacer.
Do I need more??? Thoughts, critiques, advice??? Let me know if you need more info.
Front wheel plans:
18x8
Offset ?
Rear Wheel plans:
18x8
Offset: 5.5 inches
Attachment 208182
