Results 1 to 10 of 10
Thread: fuel pump choice?
01-10-2006 #1
- Jan 2006
- 1
fuel pump choice?
I am hoping someone here can help me out. I am building a 500hp street car and I am looking for an electric, in-line fuel pump. The kicker is it needs to support 500 boosted hp, be rated for continous use, and last of all (but most importantly) it needs to be quiet. I run a Pro Star 500 on my 900hp drag car and it is a great pump, but it is loud. For a street car I really do not want one that loud. Anyone have any good suggestions for a quiet efi pump?
01-10-2006 #2Re: EFI Fuel Pump
I have an Aeromotive A1000 pump that I use and it works well. This would easily fit your application for everything but the noise requirement. I don't think I've ever heard a quiet EFI fuel pump. Even factory pumps. The A1000 is loud but, one thing I'm was going to try is the Aeromotive speed controller. Less pump at idle should be quieter. By how much, I'm not sure. Not to mention the other possitive reasons.
This is what Aeromotive say's on it:
For any pump, on any type of vehicle, the Aeromotive Fuel Pump Speed Controller (FPSC) minimizes hot fuel handling problems for in-line pumps in bypass systems and it will also keep T-style pumps cool in static systems, extending fuel pump life. Sensing engine RPM, the FPSC kicks your fuel flow into high gear when you need it, but reduces pump speed and flow to keep things cool when you don't.Ron DeRaad
68 Camaro RSx
Darton Sleeved LS9 - 434ci (4.155x4.00)
AFR LSX245 Heads (12:1cr)
660hp/588tq
01-10-2006 #3
- Nov 2004
- 261
Weldon has a good selection of pumps, give them a call and see what they'd recommend and then search RacingJunk.com or NMRARACING.COM, eBay for good used pump and regulators at half the new cost.
Gerald
01-10-2006 #4I am using a Bosch pump I got the part # from Kurt at W2W. I have two wired up so the second one comes on at 3 lbs of boost. Kurt put them on the Mule the same way they work great and are quiter than the a1000 i had before
01-11-2006 #5
- Jun 2005
- Omaha, NE
- 255
Weldon is the best pump in my opinion but it's also the loudest.
Any inline pump is going to be loud no getting around it. You can minimize the noise by how you mount it. We mount inline pumps with sound deadening material, and try to place them to reduce as much noise as possible.Jeff
01-11-2006 #6
- Aug 2004
- 582
I don't think that's true, Walbros are pretty quiet, and so far they've been very durable for me. When I put EFI on my truck, the tank was full of rust, and i had a crappy pre-filter, and the pump has survived both the clogged pre-filter and whatever got through before it clogged. The GSL-392 should support your needs.
01-16-2006 #7
