      Oct 2007
      Single Turbo vs Whipple
      I have a 2017 GMC Sierra that is my daily driver. Ive decided to convert it to a more spirited version for a dialy some light towing and 'spirited driving' fun.
      I am lowering 3 to 5 inches putting a sport truck suspension on it and air assit load bags for towing my camaro. (under 8000 total tow weight)
      It has a 5.3 and I am on the fence about a supercharger vs turbo.
      Pros of turbo.. more on demand torgue, NO whine or fulltime drag on engine. Cons Heat.. literally every kit has issues with AC lines and wiring. This can be managed. Oiling.
      Pros of whipple, Easy install easy removal. No heat issues,
      Cons i like a nice quiet ride when just going to the grocery store.. I don't care for a whine all the time.. roughly 40% more expensive.
      So help me decide..
      67 Camaro In progress
      Feb 2008
      Texas
      I was going to go with a centrifugal on my car. My reason was for the simplicity for tuning and stuff vs turbo and me being someone that doesnt want to mess with things all the time. Anyway I ended up changing my mind and am going to do a single turbo because it will cost less and make more power. Also it will be easier on the crankshaft and no belt issues. Its a difficult decision.
      http://www.youtube.com/user/cutlassrkt?feature=mhee
      69 cutlass - 5.3l L33, Jakes stage 3 4L80e, 275/40/17 proxes tq
      Mar 2020
      A prime consideration is if you already have money invested in headers/exhaust so you are not buying things twice.
      The Whipple is an easier install & will have great torque.
      I recently worked on a 6.0 with Whipple & it tows so well, you almost forget the trailer is back there... until you need fuel.
      Another thing to consider is an Eaton style charger (GM, Magnuson etc.) as they are virtually silent until you are deep in the throttle.
      Centrifugal chargers do make good upper end HP, but are not as good for low end torque (towing) as they make more boost as RPM rises & not as much down low.
      I did a turbo 01 Silverado which is also impressive, but you do have a slight spooling delay on the power transition.
      Having a boost controller is great so you can set it for durable towing or crank it up for 1/4mi. or stop light fun.
      I cannot give a clear winner here... If I was building it to race, I would lean towards a turbo. With the consideration as you build for more power & go larger, you lose the low end & have to deal with more lag.
      Positive displacement chargers will make boost down low & are very predictable & easy to install.
      Oct 2007
      I am looking at this kit
      https://www.summitracing.com/parts/m...silverado-1500
      -VS-
      This Kit
      https://hppracing.com/products/on3-2...e-turbo-system
      Quote Originally Posted by Lonnies Performance View Post
      Jul 2012
      evansville indiana
      In my opinion those aren't really comparable. On3 uses cheaply made China parts. They have R&D facility in Ohio but everything is manufactured in China. I'd either opt for a Magnuson, Whipple or a factory LT4 blower with conversion parts from Boost District. I have a Magnuson instock for that model truck as well if interested.
      Mar 2020
      I would look into the LT4 conversion.
      They are relatively cheap & of factory quality.
      With a cam, over 500rwhp is relatively easy to get & over 600 is possible, but not exactly safe.
      Oct 2007
      Thanks for the input.. going to look into this https://boostdistrict.com/collection...0-supercharger
      - - - Updated - - -
      Quote Originally Posted by bsinclair View Post
      doing some research and will reach out when ready
      Feb 2008
      Texas
      Quote Originally Posted by XLexusTech View Post
      - - - Updated - - -
      Don't upgrade the heat exchanger on the boost district kit. Just buy one somewhere else if you go that route. I had the upgraded one and it was pretty small(I bought the truck kit about 3-4 years ago or so). I found similar ones on ebay for half the price.
