    Results 1 to 12 of 12
      Sniper power with battery in trunk
      Hey Guys,
      I searched youtube and was not able to find how to power the sniper system if the battery is in the trunk?
      Please help me out.
      Vince
      Jul 2018
      Run the power cables to the trunk.. yes, that simple
      Aug 2022
      SoCal
      Doesn't really matter where the battery is. The sniper needs a direct positive and negative connection to the battery. So run some wire back to it. Or was there something else you're asking about?
      It does sound simple..I purchased the sniper, ignition box, in tank pump with return less line, distributor and harnesses so I make is as idiot proof as possible for me lol
      Sounds like I can literally just run wires near the right rocker area from battery to sniper.
      Jul 2018
      Quote Originally Posted by vince72 View Post
      Ran mine inside under the door sill plate, and out the rear seat.
      - - - Updated - - -
      Attachment 204225
      The photo did not go thru for some reason?
      Jul 2018
      20210704_134327 by F G, on Flickr
      Feb 2019
      Kankakee IL
      battery to a power distribution relay panel, through a dioded relay and fuse, out to sniper. The panel will handle your ignition switched power source.
      https://www.waytekwire.com/item/4634...i-Fuse-Panel-/
      Tracey
      Thank you for the photo. That is very nice work!20210704_134327 by F G, on Flickr[/QUOTE]
      - - - Updated - - -
      Quote Originally Posted by Tsaints1115 View Post
      Thank you for this. This seems like a good idea & I would have access to power other items
      Feb 2019
      Kankakee IL
      Hypothetically having the Sniper's fuel pump ground trigger circuit go through a common switch on it's way to the relay panel and then on to the fuel pump can be used as a hidden in plain sight anti-theft method.
      Hypothetically. ;)
      Tracey
      Hypothetically. ;)
      I wish I was more electrical savi. I am just now gaining confidence in doing the sniper install haha
      Jan 2018
      Saint Louis, Missouri
      Make sure you put the proper size fuse, breaker, or fusible link on the main power wire for the system as close as you can to the battery.
      Diagrams I have seen from Holley either shows a fuse in an improper location or none at all.
      You may want to add a fuse to the wire off of the key switch unless it is already protected.
      Jim
