    Results 1 to 20 of 31
      Nov 2022
      pro touring 65 vette starter
      I came across this 65 vette, looks like it could be a good project starter. Im no corvette expert but from what i can tell it was an original 350 car. The owner says it was modified back in the 90s before they bought it, ( flares, hood, pipes, interior) It looks solid just a couple small spots in the fiberglass need repair. Im not sure what the value is in this bad of shape. There is no engine in the car and the original engine is gone.Name:  20221112_100838.jpg
Size:  225.0 KBName:  20221112_101112.jpg
Size:  498.9 KBName:  20221112_101318.jpg
Size:  267.0 KBName:  20221112_101320.jpg
      The flares can be fixed. But the wind shield rust (bird cage per the Corvette guys) can be a killer. Also frame rust. If its been sitting on damp ground for awhile it's not going to be pretty.
      The good? It looks like it has all the window trim. Doesn't look like the front end has been modded but no bumpers?
      I assume the radiator support is still in the car? If it's rusted out on the bottom you will have rust other places.
      In 65 there wasn't a 350 only 327.
      I wouldn't touch it if I couldn't get it up in the air and get a good look underneath.
      Nov 2022
      Thank you!
      What is a good way to check the bird cage without taking the car apart? They say the car was covered outside but hasnt been registered since 2017. so I assume its been sitting for 4 to 5 years.
      I would go over to corvetteforums.com and ask the same questions.
      May 2018
      Quote Originally Posted by Knifeman1 View Post
      Thank you!
      Look closely around the windshield frame and around the dash. There is metal there that will rust. If the trim is removed, it will be much easier to spot.
      If the interior is accessible, the passenger side kick panel can be removed with a phillips screwdriver easily. If it's still clean and green from the original primer, you're probably in good shape. This area gets wet and builds rust and scale.
      Check the frame at the body mounts and in the area just behind the seat where the frame kicks up. They are bad about rusting in that area. A new frame is bad enough, but rebuilding the birdcage is tough.
      Agreed that I wouldn't consider an offer on it until I could get underneath it and do a little poking around. If the seller refuses, walk away.
      Jim..Car Junkie
      1969 Vette--Big pistons, No turbo....yet
      RX7 Turbo II--No pistons. Big turbo--now in my Daughter's garage
      68 RS Z/28, '12 Boss 302, 86 911, several RX7's, 3rd gen f-bodies, fox body, and many more..(gone)
      corona,ca.
      What are they asking for it? If it's too big of a project I'd take it on as my wife wants a 63 split,but this is as close as.shell get $$$ wise
      72 chevelle.
      Nov 2022
      they are trying to come up with a price, In the shape its in with the engine missing and body modifications I thought it would make a good pro touring build project.
      Nov 2018
      Quote Originally Posted by chevelletiger View Post
      If this doesn't work out, how "63 Vette" does it have to be for your wife?
      https://www.crcoachworks.com/models
      These guys sell rebody kits for newer Corvettes that have the older Corvette look. They aren't the same as they have to conform somewhat to the newer car and it'll be an obvious rebody kit, but they do a pretty good job of integrating the older design queues to the newer body. I've always liked them, but never used them.
      2021 Durango R/T
      2005 Dakota beater
      2003 Dakota project-o-mobile
      Grand Rapids, MI
      Did you find out anymore about this? I'd be interested if you pass on it. What state is it in?
      65 corvette, RS chassis, LS3, TKX
      Jan 2009
      San Antonio, Texas
      Sweet project! Let us know if you end up with it!
      Check out my YouTube channel for vintage car and truck rescues and rebuilds! THE BULLETPROOF GARAGE!!! - YouTube
      Grand Rapids, MI
      Did you get the car?
      Nov 2022
      I got it yesterday and got it home. I have some better pictures now i will post.
      Jun 2009
      Bangor, Northern Ireland
      I look forward to seeing pics and hearing about the vette. I've got a modded '71. like others have said Vette's don't like sitting outside, they rot big time. Hopefully you didn't pay too much for it? Although it's a great project to Pro Tour. Good luck!
      Nov 2022
      new pic
Size:  442.6 KBName:  20221217_151342_resized.jpg
Size:  516.3 KBName:  20221217_151359_resized.jpg
Size:  549.7 KBName:  20221217_151352_resized.jpg
      ';dlkfjngg;azlkjdfsg;alierjgf;oairejgfa;oirjvb;oai dfjvo;izdfjv;oizdfjv
      I know its way early but over on Corvetteforums.com there is a guy that makes a really slick electric head light motor conversion. I used it on my 71 C3 and it allowed me to get rid of all the vacuum stuff. Worked great.
      Good luck with your project.
      Nov 2022
      Thank you! Ive got to start doing my research and figure out what parts to go with. I think im going toward a weekend warrior auto cross pro touring build. detroit speed underneath, maybe new chassis or maybe stay with the original.
      Oct 2015
      Good looking project.
      My half a$$ed build thread.https://www.pro-touring.com/threads/...elle-6-0-4L60E
      Tighten it till it strips & back it off a quarter turn.
      Nov 2022
      thinking of selling
      Thinking of selling this one if you know anyone looking for one
      Grand Rapids, MI
      Is the frame and birdcage solid? Where is it located? Can you pm me a price. Or text me at 616-406-6385. Thanks
      Sep 2009
      Just throw a motor and transmission in it and drive it!
