      IL/TN
      dual racing master cylinders
      This dual master cylinder assembly was made to be a direct mount in place of the brake booster for an easy swap.
      - Bolts in place of your car's original brake booster.
      - Uses original pedals (new hole may be needed for proper pedal ratio )
      - Adjustable pedal rod.
      - Adjustable brake bias.
      - 3 in 1 reservoir system.
      - Available cockpit adjustable extension
      - Brackets Available with or without clutch slave cylinder mount.
      - Four bolt mounting reduces fire wall flex double that of others on the market or typical 2 bolt mount tandem master cylinders. (20 sq/in of firewall area VS 7 sq/in )
      - The rocker mechanism increases pedal ratio by 1.6:1, facilitating the conversion from power brakes to manual unlike direct mount versions.
      - On the shelf and ready to ship.
      - $489.00, cockpit adjuster knobs $65.00
      [FONT=&quot[/FONT]
      https://www.protouringf-body.com "doing what they say can't be done"
