      Jan 2014
      Austin, TX
      Fragola PTFE 6000 for power steering lines?
      Has anyone used the Fragola PTFE 6000 line to build their own power steering lines? For the -6 line, the advertised working limit is 3000 PSI with a burst limit of 10,000 PSI. They advertise that it can be used in power steering applications but dont specify whether you need to use the crimp fittings in a power steering application or if the standard fittings with the olive that you can assemble in a vice can be used.
      Thanks for the help!
      1972 C20 Suburban
      1964 Corvette Coupe
