Results 1 to 12 of 12
Thread: BMW wheels on a 69 Camaro
01-05-2006 #1
Won't these work on a 69 Camaro?
I thought I had heard of people running these before.
The size looks ok for stock suspension/body but unsure about b/s.
Any ideas on threse?
01-05-2006 #2Do you have a link or a picture?
01-05-2006 #3Sorry, forgot the link. Here you go.
http://cgi.ebay.com/ebaymotors/18-wh...QQcmdZViewItem
01-05-2006 #4A 38mm offset will result in a backspace of 5.5inch on the 8" rim and 6.5 on the 9", will the work or will you have fouling issues on suspension or internal arches?
1979 Oldsmobile Cutlass Supreme
Proposed mods; supercharged 350cu in Chevy, 18"/20" Billet rims, rear disc conversion, stripped interior, Dakota Digital guages.
01-05-2006 #5To fit the 8" rim on the front you need 4.75" backspacing and the rear would have to be 5" backspacing with a 9" wheel.
01-05-2006 #6Can that be adjusted with shims or I guess you can not reduce b/s with shims?
01-06-2006 #7BMW wheels are 120 MM bolt pattern, I believe your pattern should be the same as my truck, being 120.65 (or 5 x4.75")
THAT LITTLE BIT DOES MATTER!
I would not run them, unless you planned on an adapter. Which, I don't know if you could even get an adapter to adapt from 120 to 120.65
I have seen guys with s-10's run them and the studs eventually ovaled out the holes because the lugs don't seat properly.
I would not run the 120MM bmw wheels.
01-06-2006 #8
