    Results 1 to 9 of 9
      Aug 2012
      Phoenix
      Suggestions for undercar finish
      Hi everyone,
      I've recently completed replacing the floors and part of the tunnel in my car. I scuffed everything up and sprayed uPol's epoxy primer on everything. https://u-pol.com/en-us/product/coat...oxy-primer-kit
      The inside of the car will be getting lizardskin heat and sound control. What should I do with the underside of the car? I am thinking that I will at least spray the heat control directly under the seat pans but I'm looking for suggestions for the rest of the freshly primered areas.
      Kris - Building the poor man's '68 Mustang.
      Central Cal
      Hi There,
      I recently shot U-Pol Raptor on my under carriage and Lizard Skin in the entire cab.
      Everything looks super Fantastic.
      If I need additional sound deadening or thermal barrier in the interior I can always lay down some dynamat.
      On my projects I degrease first. Scuff. Eastwood primer as needed. Then Eastwood chassis black. Then just spray bomb under coating.
      Aug 2012
      Phoenix
      I ended up ordering the raptor liner in light grey.
      Feb 2020
      I sprayed southern polyurethanes epoxy and upol black on my camaro, I think it turned out great
      I also plan on spraying lizardskin in my car, can you provide pictures of what it looks like? I am interested in seeing
Size:  197.3 KBName:  PXL_20210612_000707772.jpg
      Aug 2012
      Phoenix
      Quote Originally Posted by SPG View Post
      This is the only one i have at the moment. It's not the best pic. This is the Sound Control. I'll be spraying the ceramic insulation next weekend.
      Aug 2012
      Phoenix
      This was after both coats of both the LizardSkin heat and sound control were done.
      Feb 2020
      how many gallons did you use?
      Aug 2012
      Phoenix
      2 gallons of each. But I only did the floor, trunk divider, and roof. I have read that 2 gallons isn't enough if you want to do a whole car (doors, quarters, etc) but it was enough to cover the areas i did in two coats each.
