      Apr 2022
      GMPP 376/480 Crank No start
      I have had this truck running for a couple years it has cut off while driving a few times, then started back up after a few attempts. Now I cannot get it to start at all. It is throwing a 1682 code (ignition 1 circuit 2) I have tried a new battery (per someones advice) I have tried bypassing the ignition switch, checked all fuses and relays. I can't find a GMPP pinout for the e67 ecm used on this motor to test those. any help will be much appreciated.
      Have you checked the fuel pump and have fuel pressure at the fuel rail.
      And I just have to ask do you have plenty of fuel in the tank?
      Apr 2022
      Yes, full tank and 58 psi. sometimes the pump doesn't come one though
      Apr 2022
      Double checking found a bad PT relay. So far it’s running again
