    Results 1 to 13 of 13
      Apr 2010
      Prescott, Arizona
      1969 Pro Touring Camaro LS 427 DSE
      [B] Up for sale is my Beautiful Custom Grey 1969 Camaro with Award Winning Custom Leather Interior by Ron Mangus. 187,000.00 Must see to be appreciated!
      Car is located in Prescott Arizona
      *****SOLD*******
      1969 Camaro all new steel body with clean 1969 Camaro Arizona Title in my name
      Detroit Speed & Engineering weld in sub-frame connectors
      Detroit Speed & Engineering narrowed stainless fuel tank & pump
      Detroit Speed & Engineering fuel tank access door
      Detroit Speed & Engineering Trunk close-out exhaust kit
      Detroit Speed & Engineering T-56 Transmission Cross member
      Detroit Speed & Engineering Mini tubs
      8-Point weld- in cage
      Front & Rear flush mounted stock clear glass
      Side marker lights shaved
      Shaved drip rails
      Front & Rear bumpers narrowed & tucked w/ shaved bumper bolts
      Smooth Firewall
      2” Steel Cowl hood
      Custom built front spoiler
      ENGINE & TRANSMISSION:
      LS-2 with LS7 Darton sleeves
      Precision race components 285cc heads 199-PRCLS76B285
      Titanium intake valves
      Manley severe duty s/s exhaust valves
      Manley Platinum series pistons
      BTR-LS7 micro-polished rocker arms
      BTR- Chromoly pushrods
      Chevy performance LS7 lifters
      Howard LS hydraulic roller cam
      JP performance roller timing chain
      Howard cams valve spring & retainer kit
      Eagle 4340 crank
      ARP-Cylinder head studs
      GM LS Starter
      Wegner Front drive
      Wegner 2pc hidden coil valve covers
      Shaun’s Custom Billet Intake
      Frank’s Custom Cold Air return
      Holley Sniper 102mm Throttle Body
      AUS 62lbs injectors
      PSI Wiring harness & ECU
      Stainless American Racing Headers 2” primaries
      Custom Tig welded 3”brushed Stainless exhaust with V band clamps
      Borla Pro XS mufflers
      Bowler T-56 Magnum, Close Ratio 6 Speed Transmission
      Quicktime Bellhousing
      Centerforce aluminum flywheel
      Centerforce Dual friction clutch assembly
      McLeod Hydraulic Clutch master Cylinder
      Be-Cool aluminum radiator w/ dual Spal 11” electric fans w/ black billet reservoir
      Vintage Air Gen IV Magnum Heat, Air & defrost system
      Gen IV streamline Black 3 knob vertical
      REAR SUSPENSION:
      Detroit Speed & Engineering Quadra Link
      Detroit Speed & Engineering rear tow hooks
      Detroit Speed & Engineering sway bar
      Koni Coilovers
      Speedway engineering 9” rear end narrowed to 56”
      Dutchman 31 spline axles
      Ron’s rear ends 3rd member
      370 tru-trac
      FRONT SUSPENSION:
      Detroit Speed and Engineering Hydroformed subframe w/ rack & pinion
      Detroit Speed & Engineering Adjustable Coilovers
      Raceseng Front Tug
      BRAKES:
      Wilwood Black Master Cylinder
      Wilwood Black proportioning valve
      Wilwood Aero 6 piston Front Calipers -14” Front 2 piece slotted
      Wilwood Aero 4 Piston Rear Calipers Rear-14” E-Brake 2 piece slotted
      WHEELS & TIRES:
      Forgeline Rear- 18x12 GT3C with Toyo 335/30ZR18- Trac Tire
      Forgeline Front-18x10 GT3C with Toyo 275/35ZR18- Trac Tire
      INTERIOR:
      Ron Mangus custom leather interior
      Custom built center console
      Cobra Misano anniversary seats w/ pure carbon fiber backrest
      Rear seat delete
      Billet Specialties steering wheel 14” D-Shape Formula
      HMS Motorsports –SCHROTH 4-point seatbelts
      Kenwood DDX6706S monitor w/DVD receiver
      Kenwood Speakers w/ tweeters
      ARC Stereo Amplifier
      Flaming River tilt column w/ 1”DD to ¾ polished stainless steering shaft
      American Auto wire- Classic Update Series wiring
      Guard Dawg – PBS II Push button start
      Nu-Relics power windows
      2 Vintage Air Proline brushed double louver bezel
      Modo Innovations truck release kit
      Detroit Speed and Engineering custom dash insert
      Auto Meter Ultra Lite II dash instruments
      Detroit Speed and Engineering electric RS headlight doors
      Detroit Speed and Engineering Black Billet Aluminum battery mount
      Recessed battery box in trunk
      optima battery
      Full length battery cables
      Battery shut off
      DSE /Rock Valley Stainless fuel tank W/pump
      Anvil carbon fiber closeout panel
      Full Dynamat including doors and roof
      Fesler Billet LED Driving /Turn/ lights
      Fesler tail lights
      Digi-Tails LED Sequential Tail Lights
      Detroit Speed and Engineering 7 Speed wiper motor
      Stainless hand formed brake lines
      Ride Tech billet locking cap
      Ring Brothers Door Handles
      Ring Brothers Hood Hinges
      Ring Brothers door strikes
      EM door jam vents
      Black exterior door locks
      E-Stopp Emergency Brake
