    Thread: cpp brakes?
      Nov 2012
      cpp brakes?
      Has anyone used the CPP big brake conversion with C5 spindles etc. on a 64-67 Chevelle or another A-body? They advertise it as a zero-offset system(drum brake offset) which is what I need to clear my wheel/tire setup I currently have on the car. They also have a rear brake kit that is set up for a BOP 10/12 bolt that had bolt in axles and I thought about running their product front and rear. Not sure what MC to use yet either since I'm sticking with manual brakes also. Thanks
      1970 Camaro restomod power tour ride
      1966 Buick Special restomod, the never ending project
      1970 GTO My newest retirement project, time to gather parts!
      Jun 2012
      Chicago burbs
      I had the CPP front/rear disc brake conversion(not the C5 stuff) on my 69 cutlass. The fronts were fine and definitely got me into a disc brake setup. The rears, if they are still using the D154(aka metrics calipers, aka eldorado calipers) with the integrated parking brake, are a complete nightmare. I wasted years trying to get them properly adjusted and could never get a solid pedal. Out of frustration after 6 years I swapped to the wilwood D154 caliper WITHOUT the parking brake, and instant solid pedal and better braking feel overall.
      Now, I don't know if the D154 caliper piston area is suitable to run with the C5 piston area, but it's important to make sure they percentages are correct . I would just say stay away form the D154 with integrated parking brake at all cost. Hope this helps.
      1969 442 6.0L LQ9 T56
      Fab9 w/ custom 3 Link conversion
      FAYS2 Watts link
      Thanks to Mark at SC&C for his honesty and passion for the sport, and Ron Sutton for the wealth of knowledge that has helped shape so many of the cars on this site.
      Nov 2012
      Quote Originally Posted by jetmech442 View Post
      Thanks for the info and it’s what I’m looking for as far as advise. Their system for the front is the only one I’ve come across that is a zero offset. It’s something I gotta have unless I step down on tire size which isn’t in my plans!
      Harriman, Tennessee
      I've not heard anything really good about CPP, only that they are called "Chinese Poor Products" or "Chinese Poo Poo." YMMV
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Feb 2021
      SoCal
      Personally I'd look into just swapping 4th gen F body F&R brakes. Might not be "zero offset" considering the thickness of a drum mounting surface VS disc mounting surface, but you're looking at a minute difference.
      Tobin @ Kore3 should have the width differences if you really do have the tires pushed to the absolute limit of space.
      May 2020
      The kit I'm looking at from CPP uses 11" 1979-81 Malibu brake rotors and 1981-92 S10 calipers so I'm not worried about Chinese parts.
      Feb 2011
      So CA
      CPP brake3s
      Hi Jett,
      Going through the same thing with those rear brakes on a 67 Camaro, fronts are fine. Rears are a PITA to get adjusted/blead. On your Wilwood changeover what was entailed? New Rotors, mounting hardware and such?
      Thanks in advance,
      Chris Sanford
      chris.sanford899atgmaildotcom
