      Aug 2019
      E38 ECU question
      Hi. I have an ls3 525 crate. I got the GM engine management kit, the kit comes with an E67 ECU. Im going to use a PDM in the car and Rywire makes a great harness that integrates the ECU with the PDM.
      QUESTION: The Rywire harness is set up for an E38 ECU, can I use an E38 ECU on this ls 525 without spending a ton of money.
      Thanks , Merry Christmas.
      Jacksonville, FL
      E67 has 3 pcm plugs where the E38 only has two, not really compatible with each other (harnesses). If you want to use the E38, I would just sell the GMPP kit and buy another harness (like a PSI) that is compatible with the E38.
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Aug 2019
      Thank You. I have the Rywire e38 harness. My question was can I use the E38 ECU on my ls525?
      Mountain Springs, Texas
      Quote Originally Posted by tmunroe22 View Post
      Sure you’ll need a new harness and a custom tune. Speartech can set you up.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      GM's strategy seems to have been to use the E67 for FI engines (LSA, LS9) and the E38 for NA engines (LS3, LS7, etc.). Except for the GMPP LS3 engines which are NA on the E67. Switching to an E38 really is your best bet, I'd say.
      ​John Parsons
