Results 1 to 12 of 12
Thread: master cylinder sizes?
01-03-2006 #1
- Jan 2004
- NW Suburbs, Chicago
- 560
I know theres some math out there to define what size mc is best for a specific brake set up given the number of pistons per caliper and piston size etc etc. but does anyone know the math behind it? or have a program or link to something?
also in dual mc setups, the balance bar, what exactally does that achieve?
01-03-2006 #2
- Aug 2004
- England
- 1,042
On the dual mc set the bar acts as proportion valve to the back brakes so you can adjust it. If I were to fit a brake set to car stick with production model all the way ie vette discs + master or any other model this is the easiest route as you know A it will stop the car and B it a tested system, or if going after market stick with 1 company .
paul67
01-03-2006 #3
- Jan 2004
- 560
well the reason Im asking is that on my mx6 i can adapt vr4 front calipers, so much bigger disc and 4 pistons as opposed to the stock 1. I have two options as far as bolt on masters, the stock one and the 929 master which is larger. just trying to find which would be the best fit for it. As well as understand the math behind it for future referances.
so with a balance bar you would have no more need or use for a prop valve to the rears then?
01-03-2006 #4
