Results 1 to 9 of 9
12-31-2005 #1
Has anyone made their own billet grill?
I want a billet grill for my 68 camaro, but I want it to cover the headlights, kinda RS style. All the grills I have found either don't cover the headlamps, or the full cover versions stick out too far, I want it to recess back 1/2"-1" to look right. The question I have is where do I find the bars, and how long should I expect to have into building it. Thanks
12-31-2005 #2I have built a grille for a car and ill post pics later
First do you have a tig welder? Next if you do, choose the size/shape of the bars you want to use. If you do not have a tig welder then you can do what i did. I used 3/8" square bar and drilled/tapped/countersunk into them and used #8 machine screws to hold it together.
For the aluminum check your phone book for metal supply places and you can see if they carry aluminum stock.68 Camaro - never to be finished
06 Silverado - Forged 370, L92 Heads, big cam, 4l80e ect. eventual donor for the above
http://www.youtube.com/watch?v=KmB2y7uX38I
12-31-2005 #3If you do, make sure it will weld AC (alternating current).
Originally Posted by Camaro Zach
The needs of the many outweigh the needs of the few.
01-01-2006 #4I have a mig, no tig. If you could post up your pictures of yours, I would greatly appreciate it. I just can't see me spending 400 on the ones I have seen that are a full cover.
01-01-2006 #5
01-01-2006 #6Cool, thanks. How difficult was it to fab mounts for?
01-01-2006 #7It wasnt hard at all for this car because i just tapped into the ends of the horizontal bars and those screw in from the inside of the car into the grille.
The whole grille is extremely easy to build, just very time consuming i have about 12 hours in it68 Camaro - never to be finished
01-01-2006 #8Cool, thanks again man, you have helped alot
01-01-2006 #9Glad i could help, good luck
