Thread: A/C Help After 5.3 Swap
Hi Everyone,
Recently we finished swapping a 5.3 from a 2002 Tahoe into our 97 Tahoe. It's almost as much fun to drive as our 67 Camaro was. Almost
It would be even more fun to drive if I could figure out why the A/C is not working.
This site probably has more LS swapped vehicles than any of the other sites I get information from, so I am hoping we can figure this out.
I'd like to get the A/C up and working before we take it apart to clean things up a bit.
The compressor is a Sanden 508...
We have a switch on the accumulator/drier. I think this is the low pressure switch...
We have a switch located in the high pressure line between the condenser and compressor. I think this is the high pressure switch.
There are no switches in the compressor itself. Only the wire off of the compressor itself that is supposed to make the compressor kick on when it gets the signal from the computer.
I have found a few different wiring diagrams, but have not had any luck.
This one seems pretty straight forward. I am getting the +12 signal from the HVAC control module. The Compressor Relay in the Underhood Fuse Box is wired correctly, but it's not getting a signal to tell the compressor to go. To get the system filled with freon we bypassed the high and low switch and sent the signal from the HVAC Control Module to the A/C relay.
I guess it's possible that both the high and low pressure switches are bad. Is there a way to check them, or do I just replace them? I'm guessing they aren't that expensive.
Then there is this wiring diagram...
Both wiring diagrams are only using C2-43 and C2-17 on the computer. The second wiring diagram has the low and high pressure switches connected like the first, just at different pins on the connector.
Then there is this wiring diagram. I think it's for a van.
It has things hooked up differently.
So I don't know if any of these wiring diagrams are correct, or if there is a more universal approach to this. I don't know if I have the switches under my hood labelled wrong. I can't help but think this is a pretty simple thing to fix. The A/C shops I have talked to around these parts don't deal with wiring.
