    Results 1 to 1 of 1
      Nov 2013
      Wichita
      G-Comp Unser Edition 1970-81 Camaro Front Subframe
      • The Unser Edition is an enhanced G-Comp front end with the following components:
        • Subframe features a chassis brace machined from billet aluminum
        • The billet chassis brace holds the upper shock mount
        • The upper shock mount position is adjustable, permitting use of multiple length shocks - Adjust your shocks in minutes!
        • The new upper shock mount provides clearance for springs with large wire diameter
      • Upper control arm is designed with an additional 3° caster over standard G-Comp arm
      • Lower control arm has a recessed front strut to increase tire clearance
      • Up to 275/35 R18 tires can be used in competition
      • Steering arm is designed for a 20% quicker steering and increased Ackermann
      • Overall increased camber gain over standard G-Comp kits
      • Kit comes with a 0.250" wall - 1-1/4" O.D. sway bar
      • Allows for a large range of front ride height adjustment, working with a wider range of shock lengths and strokes
      Standard features:
      • Complete bolt-in front frame assembly replaces stock subframe
      • Will work with 14" through 16" long shocks - not included
      • Multiple hub and brake packages available - not included
      • Choose your brake kit and coil-overs from the options listed below
      Anyone have this setup in there car?
      Wondering how it compares to Detroit Speed and Speedtech subframe.
