    Thread: Interior advice
      Dec 2017
      Interior advice
      Like the tittle says I’m looking for some advice. I’m currently working on my interior and want to lay down some membrane. The car needs to be painted, probably taken down to bare metal so probably sandblasting or something along the lines. I don’t plan on doing paint for awhile (years) I want to enjoy it. Would it be a bad idea to lay down some membrane down before doing that ? I’ve replaced all floor pans that have had damage, subframe connectors are already welded in. I have a restomod air unit sitting in box, trying to make the most out of it.
      Sep 2016
      Bakersfield, CA
      If you plan on doing a complete down to bare metal paint job in the future, I would just add old school carpet jute and skip the "membrane" for now. At the most, I would put some "membrane" on the inside of the firewall and over the trans tunnel.
      Otherwise yeah, it will be a total PITA to remove and whether you chemically strip or mechanically strip when you go to paint, it's going to be a PITA. JMHO.
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      Aug 2015
      charlotte
      Yeah it'll really come down to the extent that your future bodywork will go. If your floors are perfect, protected in epoxy and never need to be looked at again, you could add the membrane, but you may have to be prepared to pull it all up if your body-guy deems it necessary
      Apr 2021
      By membrane do you mean something like Dynamat?
      Jul 2011
      Nashville/ Tampa
      There's no reason to put membrane in parentheses.
      https://www.restomodair.com/shopprod...mal-insulator/
      Regardless, it'll be a pain to get off later. I went ahead and put a box in my car but full plan to replace pretty much all the metal in floor eventually.
      https://www.instagram.com/gen_v_lt1_chevelle/
      Do not buy anything from Frankie's Used Auto Parts. Ever.
      Chevelle ̶a̶l̶m̶o̶s̶t̶ ̶f̶i̶n̶i̶s̶h̶e̶d̶ L92/200-4r now Gen V LT1 and T56- https://ls1tech.com/forums/conversio...nvertible.html
