    Results 1 to 14 of 14
      Orange County, CA
      Exhaust fabrication question
      How do you calculate the angles and lengths when trying to put an offset into an exhaust pipe? I would be cutting and welding the offset from pre bent mandrel tubing. For example, I want to move the exhaust pipe over 1” to the side. Thanks
      Sep 2007
      York, Pa
      I just eyeball it until it makes sense. I've done some high end exhaust and headers just eyeballing and making reference marks with a sharpie. Occasionally I will draw some reference angles on the workbench so I can duplicate left and right sides but I definitely don't spend much time on calculation.
      Justin Snow
      Martinez, CA
      I’m not sure about the geometry but 1” isn’t a big offset. Over what length do need to make the offset? A couple of pie cuts may get you there. One cut to change the angle and an opposite cut “x” distance down the pipe to continue in the original direction. Don’t even cut all the way through. Leave just a tab to hold it togeather.
      I’d practice with a cardboard tube and tape.
      Worlds Fastest LFX powered 1966 Chevelle, with a 3.6L/217 CI, 4 cam direct injected V6, 6 speed auto, full Hotchkis suspension, 4 wheel Wilwood discs, white w/red interior, cowl hood. 3260 lbs w/full tank.
      Orange County, CA
      Thanks for the info. I’m trying to make a bend similar to this picture that I found online. I thought there might be a formula that would tell you how many degrees each direction, and maybe what lengths to make the bend to adjust the offset amounts. But I suppose I could just eye it and get pretty close, that’s how I end up doing most thing anyhow.
      Feb 2013
      South Carolina
      It's just trigonometry if you're dealing with standard offset angles. Basically figuring out the vertical leg length of a triangle.
      I whipped up a CAD model and table for some common distances when I was working on mine.
      Martinez, CA
      Quote Originally Posted by JustJohn View Post
      Nice drawing. I would guess that changing the 45’s to 30’s would get close to a 1” offset. I always wished I knew how to use CAD but never had a need.
      Orange County, CA
      That’s awesome, thanks. I see in your drawing, for a 2.2” offset, you’d need no additional section length. How would you accomplish a smaller that 2.2” offset? I assume you change the angle from 45* to something smaller, depending on how much offset? And if you wanted to make a larger offset, while keeping the section length short, you’d just use a larger angle?
      Mountain Springs, Texas
      Nice!
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jul 2008
      Quote Originally Posted by 67-LS1 View Post
      Look up Google sketchup, it's free 3D modeling software with a large user base. Can usually find answers to your questions or find a forum with responsive people to help you out. I started out on it years ago designing speaker enclosures.
      *Jeff*
      Feb 2014
      If you have a friend who’s an electrician ask him to use his math skills. It’s basic trig and a right triangle, remember sin cosine and tangent.Your lengths and angles should be exact using math and a good chop saw.Or you could always just use a piece of cardboard scissors and a felt pen and wing it.I ended up using both methods.
      Feb 2013
      South Carolina
      You can't do it with the same 45 deg mandrel bends off the shelf. Ace Race sells a tight radius bend which saves ~ 1/2". Otherwise, you're looking at cutting into the bend or using less than a 45.
      If I get ambitious today I'll put together some line drawings with different off the shelf bends.
      Quote Originally Posted by 65 drop top View Post
      Feb 2013
      South Carolina
      It's the bend radius that drives some of it. You can't have a negative "B" length.
      Somebody mentioned 15 degrees? Not my choice to work with but:
      2.5" Mandrel Bend Radius, 15 Deg Bend Angle
      Offset A Section length B
      0.5 0.944
      1 2.875
      1.5 4.8
      2 6.74
      2.5 8.67
      Feb 2013
      South Carolina
      2.5" Mandrel Bend Radius, 30 Deg Bend Angle
      1.0" 0
      1.5" 1.1
      2.0" 2
      2.5" 3
      3.0" 4
      Orange County, CA
      Awesome! Thank you. How does pipe diameter effect this, going from 2.5” to 3”?
