    Page 1 of 4 1 2 3 4 LastLast
    Results 1 to 20 of 67
      Mar 2021
      Manitoba Canada
      Project Snake Charmer - 1972 Celica with the heart of a 2015 Mustang
      My Good friend Tony and I are building a Pro-Touring car out of my 1972 celica parts car. I am not sure if an import can be classed as a pro-touring car but that is the theme we are going for with the build.
      This car was headed for the crusher before I brought it home. The car has been 2 years in the works. I probably have 400 plus hours of fabrication in it. This is our wide body 1972 Celica race car. Well at least it was a VERY rusted out Toyota Celica when it rolled into my shop, it was my parts car. This build was supposed to be a quick and dirty build to go hoon around in. We were going to throw in a high hp motor and see how long the little toyota rear diff would last. Well this project has gotten out of hand and over the last two years has slowly become a very modified and very radical build! Potentially one of the most unique 1972 Toyota Celicas you will come across!
      Some back story: I was looking for parts for a different build about 15 years back at a local wrecker where I came across the shell of a car I had not seen before. Turns out I liked the shape of it and the badges said celica. So I spent 10 years looking for a 1971-1973 Celica. My dad called me up one day and said he had found a 1972 celica sitting in a town 20 minutes from my house. The car was not for sale but after a couple visits the owner decided to sell me the car for $900 bucks. I was going to restore this very rusty car. Then another member of the Winnipeg Sports Car Club emailed me a Kajiji add link for a 1973 Celica. It was sitting on a farm an hour out from me for $150. So Now I had 2 Celicas sitting in my garage and the $150 celica was in better shape. So I spent the last 5 years restoring the 1973 celica and my 1972 became a parts car.
      About 2 years ago Tony picked up a completely totalled 2015 Mustang ecoboost. His plan was to put the 2.3 ecoboost into his fox body Mustang. I said "we should throw that 300hp motor into my parts car and take it auto crossing till the puny differential blew". "A cheap car to go do some Hooning in!" Surprisingly a few weeks later he said that sounds like a good idea. Tony is a Ford guy and not a fan of Toyota. So while we were fitting the motor in the car we knew the trans tunnel was going to have to be made from scratch to fit. The motor fit perfect after the tunnel was cut out. We sat there for about 20 min looking at the motor sitting in the engine bay of the celica. It really only needed engine mounts and a new drive shaft to go with the new trans tunnel to go racing. We said to each other "The easy way or Hard way?" well we chose the hard way. This ment getting a 50:50 weight balance which included setting the motor 18 inches back under the cowl. From there it got pretty crazy with a full scratch built chassis incorporating the rear independent sub frame from the 2015 mustang and a 1990 miata front sub frame. The mustang is 14 inches wider than the celica. I finally got the chance to try the quarter panel stretch I had seen done on some first gen Camaro's
      The name "Snake Charmer" came about when we realized our power to weight goal for the car put us in Dodge Viper power to weight range.
      Goals for the car:-2200lbs total weight-$10000K canadian dollars budget -completely new hand made chassis-set the motor 18 inches back over stock (just behind the strut towers, -install a 2015 mustang 2.3L EcoBoost and its 6 speed manual gear box-390 hp-then 500 hp-install a na miata front suspension/subframe-install 2015 mustang Independent rear suspension- full Metal Wide body!-Run it hard at autocross and time attack events!
      I have the whole build is
      documented on my youtube channel: Dad's Toy Garage.
      https://www.youtube.com/channel/UCoyYP5fmRkgJLEAr8SSQyQQ
      The Project Snake charmer build series:
      https://youtube.com/playlist?list=PL...FL1E72bOL9n98l
      Latest build video update:
      https://youtu.be/82cSbEO5Mkk
      and my 1972 Celica restoration:
      https://youtube.com/playlist?list=PL...zZ8Ih7sTGGnR6Q
      Mar 2021
      Manitoba Canada
      the car when I bought it: Name:  IMG_4232.jpg
      Name:  IMG_7727 copy 2.jpg
      Name:  IMG_7731 copy 2.jpg
      Name:  IMG_7737 copy 2.jpg
      Name:  IMG_7742 copy 2.jpg
      Name:  IMG_7746 copy 2.jpg
      Aug 2002
      Waleska Ga.
      Sick!!! Cool project! More pictures of frame and suspension, motor and transmission. Please!��
      David Sloan
      Jun 2016
      Oh hell yeah! I have a soft spot for the liftbacks, but the early coupes have their own charm as well.
      Mar 2021
      Manitoba Canada
      Quote Originally Posted by Toccoa View Post
      Sweet thanks for checking out the build!
      - - - Updated - - -
      Quote Originally Posted by David Sloan View Post
      Sure I can see if I can dig some up.
      Mar 2021
      Manitoba Canada
      I went out and snapped a bunch of pictures:
      jacking in the centre lifts the car evenly.
Size:  524.8 KBName:  IMG_7989 copy.jpg
Size:  496.1 KBName:  IMG_7988 copy.jpg
Size:  501.6 KBName:  IMG_7987 copy.jpg
Size:  510.4 KBName:  IMG_7985 copy.jpg
Size:  416.8 KBName:  IMG_7983 copy.jpg
Size:  388.3 KBName:  IMG_7981 copy.jpg
Size:  593.2 KBName:  IMG_7980 copy.jpg
Size:  565.9 KBName:  IMG_7991 copy.jpg
      Mar 2021
      Manitoba Canada
      and some more photos of the chassis
Size:  371.3 KBName:  IMG_7993 copy.jpg
Size:  406.1 KBName:  IMG_7992 copy.jpg
Size:  358.5 KBName:  IMG_7997 copy.jpg
Size:  398.5 KBName:  IMG_7998 copy.jpg
Size:  434.4 KBName:  IMG_7999 copy.jpg
Size:  434.7 KBName:  IMG_8001 copy.jpg
      Nov 2018
      Nice, but I see a possible issue with the shifter - that sits pretty far back. Have you done any test shifting yet?
      Mar 2021
      Manitoba Canada
      I agree. One of the items we have on our to do list! probably once we have both new seats mounted in the car I will tackle the shifter.
      Nov 2018
      Cool. Looking forward to seeing this one done. Japanese cars from the 1970s are highly underrated IMO.
      Apr 2011
      Rosser Manitoba Canada
      I love the fact that there are a few more Manitobans on here being creative. I have seen a few of your videos and I am impressed.
      Both of our builds appear to be excessive which makes them just about right!
      The biggest thing in Motocross!
      My 97 Cougar Transcona, https://www.pro-touring.com/threads/...-Dirty-Old-XR7
      Dec 2015
      Cool build!
      Mar 2021
      Manitoba Canada
      Awesome thanks for following along!
      Quote Originally Posted by egoman View Post
      Nice I was assuming there would not be many Canadians on this forum, so thats cool to have a couple Manitobans on here. Thanks for watching my videos!
      Quote Originally Posted by 813Demon340 View Post
      Cool build!
      Thank you!
      Mar 2021
      Manitoba Canada
      I am installing the passenger side rocker panels. I am pretty excited to do the side exit exhaust through the rocker panel! I have the tail pipe fabricated and the portion of rocker panel ready to weld in place. now I need to finish boxing in the rocker panel to prevent exhaust gasses in the cabin.
Size:  394.1 KBName:  IMG_8019 copy.jpg
Size:  482.8 KBName:  IMG_8041 copy.jpg
Size:  377.8 KBName:  IMG_8042 copy.jpg
Size:  442.9 KBName:  IMG_8047 copy.jpg
Size:  503.5 KBName:  IMG_8048 copy.jpg
Size:  450.5 KBName:  IMG_8049 copy.jpg
      Oct 2010
      SLC
      I love this project. Keep up the good work.
      Zach
      Aug 2002
      Waleska Ga.
      Sweet! Keep the updates coming!
      David Sloan
      Mar 2021
      Manitoba Canada
      Quote Originally Posted by Zachalanche View Post
      Thank You!
      Thank You!
      Oct 2011
      Cincinnati Ohio
      Sorry to say I’m not a real fan of import cars but I really like what your doing, keep up its looking good.
      Mar 2021
      Manitoba Canada
      Quote Originally Posted by Kcrain View Post
      Thanks for the complements and checking out the build!
      This is awesome!
