    Page 4 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 ... LastLast
    Results 61 to 80 of 245
    1. #61
      Aug 2002
      Waleska Ga.
      Working on fuel pump and fuel line access today. Had to notch the bed cross member to allow more access.
Size:  469.3 KBName:  IMG_5224.jpg
      David Sloan
    2. #62
      Aug 2002
      Waleska Ga.
      So this morning I wanted to get a look at the amount of access to the fuel pump and lines, I knew it should be good but never hurts to double check. I’m happy with it!Name:  D561D9D2-12D8-45EE-90C8-AB6298116EC8.jpg
Size:  665.5 KBName:  C0046137-B124-4EDB-90B3-36C16E8E2DBF.jpg
      David Sloan
    3. #63
      Aug 2002
      Waleska Ga.
      One more thing done! fuel pump access door.Name:  D21B2350-7C95-4426-AA51-FA0415254205.jpg
Size:  691.4 KBName:  EF1429DB-4645-4263-87EA-BEC7205E93D5.jpg
      David Sloan
    4. #64
      Jan 2016
      Wow nice project, David! I like that you took the leap of cutting out your floor to integrate it into the frame. That would have probably saved me time and given me a stiffer structure yet, but it's a commitment for sure. Looking good!
      Chris Johnson
      '66 Chevelle Malibu
    5. #65
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by WildCherry66 View Post
      Thank you sir!
      This car was pretty bad as far as the floors went (Rusty) I wanted to make the frame more ridge so it just made since to me to cut the floor out an incorporate the body and frame together (no body bushings) once it all said an done i will weld the body and frame together then it will become more like a unibody car only with a frame. In my mind it should be very stiff, I can tell just from putting it on the rotisserie that it is very ridge as I didn't see it sag any. I have put stock Chevelle frames on a rotisserie and they would be sagging.
      This car was headed to the crusher if I had not found it when I did.
      David Sloan
    6. #66
      Jan 2016
      Quote Originally Posted by David Sloan View Post
      Thank you sir!
      Yeah that’s a nice way to do it. Maybe for my next project we’ll consider going that route.
      Chris Johnson
      '66 Chevelle Malibu
    7. #67
      Aug 2002
      Waleska Ga.
      One more mock up before the tank goes back in the box.Name:  41D518A2-8E1F-418A-805D-5F0B0A0CA85C.jpg
      David Sloan
    8. #68
      Maryland
      Nice trap door!!! Awesome progress Dave
      Ron Schwarz
    9. #69
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by Ron S;[URL="tel:1352047"
      1352047[/URL]]Nice trap door!!! Awesome progress Dave
      Thank you sir!
      David Sloan
    10. #70
      Dec 2008
      Detroit
      Nice progress you're making over there!!!
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
    11. #71
      Aug 2002
      Waleska Ga.
      Thank you sir!
      I been cutting rusty driver side wheel tub out , repairing and putting it back in today. Almost done with the driver side.
      David Sloan
    12. #72
      Aug 2002
      Waleska Ga.
      Today’s work repairing the rear wheel tubs and a mini tub. I got the driver side cut out then went about figuring out how to fix the rust and widen the tub to 1.75”s . So as you can see in the pictures I came up with this! The inside of the bed was beat up pretty good so while I had it out I hammered the dents out .
      I have some clean up to do and finish the inside to weld the last strip in and I will be happy with it!
      Repair what you got without spending a bunch of money.Name:  C7E6AF13-A915-4849-91D8-AE6E04550FC3.jpg
Size:  527.6 KBName:  884724AA-6343-4D93-9F0F-9ECD024AD822.jpg
Size:  406.6 KBName:  D8B23084-63DD-4C9F-96BC-290BA3D3C23E.jpg
Size:  576.3 KBName:  E4E32222-BA6D-457A-99E2-B64BD058F4E8.jpg
      David Sloan
    13. #73
      Aug 2002
      Waleska Ga.
      Took the day off from the car to clean up the garage. Still not done but much better.Name:  8D249BCA-1414-46B3-96A7-D0AB8D4786F3.jpg
Size:  509.5 KBName:  DAA3E858-4A27-4148-81B9-095DA70B9565.jpg
Size:  490.1 KBName:  C6E82940-ED6B-479A-8C84-B292A451BAFD.jpg
      David Sloan
    14. #74
      Nice job! It looks great.
    15. #75
      Grayson, GA
      If anyone can take a box of rusty parts and turn them into something cool........you can. Looks like you're making a lot of progress so far.
    16. #76
      Aug 2002
      Waleska Ga.
      Thank you sir!
      - - - Updated - - -
      Quote Originally Posted by 69rs;[URL="tel:1352181"
      1352181[/URL]]If anyone can take a box of rusty parts and turn them into something cool........you can. Looks like you're making a lot of progress so far.
      Thank you sir! Long time no here.
      how are y’all doing?
      David Sloan
    17. #77
      Grayson, GA
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by 69rs;[URL="tel:1352261"
      1352261[/URL]]Doing good! How are y'all doing?
      same here doing well!
      trying to navigate around the madness 🤔
      David Sloan
    19. #79
      Aug 2002
      Waleska Ga.
      Little more mini tub! It’s a patchwork but it’s didn’t cost much and it will ad to the strength of the frame and body!Name:  24E19039-348B-437C-9971-984AB3838CD8.jpg
Size:  477.3 KBName:  475C27E2-3974-4302-9EFB-318F6E31E56B.jpeg
Size:  473.9 KBName:  8D1F38EE-CD0E-49C3-B230-4A4AE1DC2F73.jpeg
      David Sloan
    20. #80
      Jan 2009
      NYC
      what wheels are those backspacing and tire size
      yes it does have positraction
