    Page 12 of 13 FirstFirst ... 2 7 8 9 10 11 12 13 LastLast
    Results 221 to 240 of 245
    1. #221
      Aug 2002
      Waleska Ga.
      69 Elcamino project
      Made some mounting brackets for the overflow tank,.
      Baby steps ��Name:  EAFBBF18-6B65-4A4F-86CE-DD4C931CB7D4.jpg
Size:  300.3 KBName:  027D9349-5289-4D35-94B9-3D66FE915CCE.jpg
Size:  364.6 KBName:  F802AC98-C6BA-4184-9E40-DE13FD810427.jpg
Size:  308.8 KBName:  5E7E4432-1D13-48BA-8D9B-998C044F3442.jpg
      David Sloan
    2. #222
      SF Bay Area
      Nice setup. Unusual to see a overflow tank with a sight glass on it. How do you plumb it up with two barb fittings?
      chunger
      '68 Ranchero 500
      '70 Cougar XR-7 Convertible
      '98 Mustang GT Convertible
    3. #223
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by chunger;[URL="tel:1389803"
      1389803[/URL]]Nice setup. Unusual to see a overflow tank with a sight glass on it. How do you plumb it up with two barb fittings?
      the bottom barb fitting is the in from the radiator the top is the overflow. Not sure how well that sight tube will hold up, but I can always cap it off.
      David Sloan
    4. #224
      Aug 2002
      Waleska Ga.
      69 Elcamino project
      One more piece of the puzzle.
      I’m guessing I’ll have 40 hours in this when it’s done.Name:  B887D193-20C9-47A2-86DF-5C208F946B5C.jpg
Size:  317.9 KBName:  D029E84D-90EF-4FC3-BC98-CC59EEB1B6C8.jpg
Size:  413.7 KBName:  0490E85F-4E4F-440B-80D7-FFD002286676.jpg
Size:  371.8 KBName:  EE729D67-5A18-48D7-B810-A5FB8A79321E.jpg
Size:  470.1 KBName:  0488F5C4-DE84-4C05-A63B-129F07F57B9A.jpg
      David Sloan
    5. #225
      Sep 2013
      sw Kansas
      I like your estimate. What are you going to use for a dash covering?
    6. #226
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by wfo guy;[URL="tel:1389823"
      1389823[/URL]]I like your estimate. What are you going to use for a dash covering?
      I have a original dash pad if that’s what you are talking about, it needs some repairs but is useable.
      the metal parts of the dash will be painted probably black.
      thank you sir.
      David Sloan
    7. #227
      Aug 2002
      Waleska Ga.
      Working on the 69 Elcamino project
      Seams like everything I want to finish up on I wind up have to order more parts ��
      Started trying to finish up the A/C lines and I have plenty of fitting, just not the one I need. I got all hooked up but one. A # 10 90% fitting and it will be Tuesday before I can go to the hydraulic store to get it .
      So I move on to the brakes started putting everything together so I could bleed them out , well I got it all put together but one banjo bolt for the front calipers.
      I got the new ignition key cylinder in and installed though.
      Little here little their.Name:  F1CE4467-E218-4E9E-AA38-2DCD6B46A914.jpg
Size:  539.7 KBName:  700C85F7-0B4C-4795-9D85-52E3ACE26B1E.jpg
Size:  380.0 KBName:  386A48AC-6D56-43C7-A52A-61CE27D4E247.jpg
Size:  412.6 KBName:  992B94B2-E733-41E0-88DD-301237DEF613.jpg
Size:  579.2 KBName:  027BCD1D-CF5B-4B86-9DD6-59A50535E135.jpg
      David Sloan
    8. #228
      Aug 2002
      Waleska Ga.
      69 Elcamino project
      Holley terminator X wiring harness for the motor and the computer installed.
      I mounted the computer to the dash in a way that I can see the indicator lights , and can be seen just under the display.Name:  F41A18F3-9223-4A0D-B471-8EBF8484BB42.jpg
Size:  357.9 KBName:  6DA3242D-454F-4268-9F30-4310DC80CBCA.jpg
Size:  408.5 KBName:  177A363E-B1FC-4DB6-843E-86F75705BE07.jpg
Size:  351.9 KBName:  05249258-D038-45B7-AA22-D21B67D7A984.jpg
Size:  414.3 KBName:  7DBC2AD9-B692-4717-816D-A785C94197EA.jpg
Size:  409.8 KBName:  F8162A01-F548-48C7-8EA7-DF9AA7215669.jpg
Size:  494.6 KBName:  73FFEF62-01BB-4ED8-AFCD-ED03AAF58D44.jpg
      David Sloan
    9. #229
      Aug 2002
      Waleska Ga.
      69 Elcamino project
      Got the nasty work done this morning!
      Sandblasted the back side of my beat up bumpers then epoxy primed them,
      Blasted the bumper brackets last night in the connex trailer where my homemade blasting cabinet is at.
      Put 3 coats of epoxy on them all.Name:  D9B44DB3-DFF2-46AE-826B-5452C2914A4B.jpg
Size:  338.5 KBName:  DDBB15E6-0C89-4106-88E7-503E06B3A6E3.jpg
Size:  769.2 KBName:  A75202D4-0360-4D37-AECD-77983A6989E2.jpg
Size:  598.9 KBName:  E1C7EDC1-AB9D-4B40-83B0-7E46D0FD0D02.jpg
Size:  500.1 KBName:  679C592E-7ED2-4663-856B-0465C820FEF0.jpg
      David Sloan
    10. #230
      Looks great!
    11. #231
      May 2012
      Kansas City, Missouri
      That's a cool idea doing epoxy on the back side of the bumpers. They look awesome. I may do that with my blazer and maybe even do the bed liner on top of the epoxy
    12. #232
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by ryeguy2006a;[URL="tel:1391310"
      1391310[/URL]]Looks great!
      Thank you sir!
      the bumpers are pretty beat up but should be fine for this build
      - - - Updated - - -
      Quote Originally Posted by thumper877 View Post
      Thank you sir
      David Sloan
    13. #233
      I've missed a lot, Nice work it looks great.
    14. #234
      Aug 2002
      Waleska Ga.
      Thank you sir!
      David Sloan
    15. #235
      Aug 2002
      Waleska Ga.
      69 Elcamino project
      Another piece of the puzzle done.
      I had made a different cover that was raised about an inch, but the more I looked at it the more I didn’t like it. So I made this one.
      Serviceability is one of my pet peeves
      , when I’m building a car from scratch or customizing one . I always look at it from the standpoint is it serviceable without taking half of the car apart.Name:  D3DEFF58-E8B9-4B44-8F31-73CBC57661A7.jpg
Size:  409.3 KBName:  01EED5B2-A85C-4DEF-9ECB-C5C935185FA5.jpg
Size:  888.0 KBName:  BD0536D1-5C1D-45A9-A708-BD20F3258D64.jpg
Size:  357.8 KBName:  1FC89FBC-A04B-4730-B00D-CB2B4F78711A.jpg
Size:  521.4 KBName:  A68F1200-63EF-4347-8AA6-12494AF1861A.jpg
Size:  373.5 KBName:  0AD660D1-8D6E-4AEB-BB3C-CFF1C28D81C6.jpg
      David Sloan
    16. #236
      Nov 2000
      O-town
      Hail Dale!!!
    17. #237
      Sep 2013
      sw Kansas
      That's my style. The logistics of maintenance are an important part of any build. If we can avoid the multiple steps for disassembly, it's nice.
    18. #238
      Aug 2002
      Waleska Ga.
      Quote Originally Posted by wfo guy;[URL="tel:1392040"
      1392040[/URL]]^^^
      Thank you sir!
      you know we would never beat the crap out of a car and brake it I really plan to drive this thing everywhere. So I’m trying to make it as easy to repair as possible.
      David Sloan
    19. #239
      Aug 2002
      Waleska Ga.
Size:  415.6 KBName:  71C3F343-6E37-4E2D-A5C0-67DB735ED038.jpg
Size:  458.0 KBName:  09683583-6F21-49DA-BE0F-F0B9C7E18D6B.jpg
Size:  596.8 KBName:  DAD6BC25-4A6F-45FA-901A-5DC62AD1A11E.jpg
      69 Elcamino project
      Got busy this morning epoxy primed the dash, then I finished wrapping the exhaust tubing an painted it with the DEI black silicone paint.
      Then I installed the exhaust tubing back in the car!
      David Sloan
    20. #240
      Nov 2000
      O-town
      David you quit on this ??
      No updates for awhile,
