      Oct 2013
      Help converting a 69 camaro standard to RS
      Okay so my car was originally a standard run of the mill 69 camaro, I would like to convert just the front end to a RS front end. I’ve read some places the fenders and inners need to be replaced others say you don’t need to do all that? I have speedtechs deep front tubs for the extreme frame do I need to modify them to run the hideaways? Also I was planning on using the DSE motors
      Mountain Springs, Texas
      I prefer the Retro Electro RS kit over the DSE. I’ve installed both. The DSE is a bit of a kludge imho. I have Anvil inner fenders and did have to drill a hole in them. You can use standard fenders by attaching brackets if yours don’t have them.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Central Florida
      Don
      I'm with Don on the headlight motors... Retro Electro kit is much simpler I have used two kits with out any issues.
      You can also get these adapter for the fenders.
      1969 Camaro Rally Sport Fender Conversion Adapter Brackets, Pair (camarocentral.com)
      BB
      Jul 2018
      3rd for the Retro-Electro although I have a 68 but they were great to install
      Oct 2013
      Don
      Does the retro kit come with a template on where to cut the inner fenders such as the DSE?
      Central Florida
      Not sure if they included templates for 69RS. I did 67 & 68's.
      Here is the instructions...
      Retro-Electro instructions, PN-004 (retro-electro.net)
      BB
      Quote Originally Posted by 71maroesteban View Post
      You just have to drill one hole, not very complex. It’s just a clearance hole for the motor, position is not critical.
      As I said, the Retro Electro solution is simpler and more elegant than the DSE imho...
      Don
      Oct 2013
      Don
      Thank you for the insight Don. I’ll go ahead and do the retro electric
