      Sep 2009
      Need help finding the fitting size for CTS-V V2 Power Steering Pump
      Hi all,
      I wasn't sure exactly where to put this since I didn't see a section directly related to the engine accessories, but figured since steering components are closely related to suspension that this would be appropriate. Mods, feel free to move if there is a more appropriate section that I missed.
      I'm putting an L92 motor with LSA supercharger and accessories to replace my LS1 and I am trying to re-use the power steering hose that I had which fits perfectly in my Camaro. I have an JGC steering box and power steering pressure hose for a 98-02 Fbody LS1 car. It worked great in my car, and would like to retain it if possible. I'm waiting to hear back from Turn One right now, but I found that they have a fitting that will adapt the ZF PS pump fitting to -6AN. However, I would like to just keep the stock hose that I have if possible. I'm finding very little information online, but what I can tell is the ZF pump I have has a different fitting on it than the M16x1.5 Oring that was on the GM type II pump I had.
      So I'm thinking that if I can find out what the fitting is, I can either get the correct fitting and have a shop modify the hose I have that fits my engine compartment, or I can find a new flow valve that has the same M16x1.5 oring fitting I already have. I looked on RockAuto for a EDELMANN 92871 hose and the fitting looks completely different.
      I know that the LSA motor is pretty popular, so I'm sure I'm not the first one to come across this issue. Any help would be great.
      Ryan
      Oct 2011
      Since turn one makes the fitting wouldn’t they know the threads? Since you’ll need the reducer anyway maybe you can buy their reducer and find an6 to whatever threads you already have? I think that may be easier?
      Sep 2009
      The turn one fitting replaces the flow restrictor/adapter that comes in stock form and goes directly into the pump. Stock the flow restrictor screws into the pump and the hose threads into the flow restrictor/adapter.
      I may be able to do what you suggested, I want to see what Turn one says first.
      Beach Park IL
      C5 corvette hose will work assuming JCG box means Delphi 600 box.
      And they are cheap.
      Donny
      Apr 2010
      Cove, Texas
      If you have the Toyoda pump for the CTS, the turn one adapter will work. The Corvette will not. I used the Turn one on my CTS pump, no problem.
      T,
      Sep 2009
      I figured some pictures would help. I test fit the PS hose that worked with my LS1 GM Type II pump, and it does thread into the ZF box, but it runs out of threads before the o-ring can seal.
      Aug 2008
      I know this is a really old thread, but I found this looking for the same fitting. For the CTS-V2 (2009-2015) this pump takes a special nut and hose. The hose is still available for the V2 from GM, but it comes without the fitting needed to install the hose onto the pump… I spent the better part of a day trying to find something that would work, and I found a ford part number that looked similar so I ordered it. It’s exactly the right size and shape. It fit perfectly onto my new high pressure line, the ford PN for anyone looking for the same thing is 7C3Z-3F656-A
