    Results 1 to 10 of 10
      Jul 2018
      brake line double flare tool, what's good & cheap?
      I know, good and cheap don't go together but, I need a double flare tool that I'll probably only used a couple times. I need one that I can do the flare on a line still in the car so needs to work in a semi tight space.
      Suggestions?
      Mountain Springs, Texas
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Feb 2019
      Kankakee IL
      I picked up one of these to accompany the full on bench tool I bought. So far this is the only one I've used. Works well.
      https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
      Tracey
      Michigan
      I use this one for on car work:
      https://www.amazon.com/Cal-Van-Tools...55153146&psc=1
      It's a lot better than the bar clamp style but obviously not as good as the clamp in the vise and pull a lever or hydraulic ones.
      - Ryan
      Jun 2010
      Deployed
      Quote Originally Posted by stab6902 View Post
      I second this style...I used NICOP tube, but this is far easier than the bar type.
      1970 Camaro/DSE build
      Jul 2018
      I ordered the Cal-Van 165 master kit .. thanks guys
      Lawrenceburg, TN
      Jun 2012
      Golden Valley AZ
      John Rodko
      69 RS/SS Camaro.
      Heidts Pro G IRS w/ 3:90 gear, Heidts Pro G front
      6.0L LQ4 to be TT
      6 speed or 4L80E, that is the question..hmmm
      Future plans for full TMI interior
      Jul 2018
      It worked pretty good for my first attempt
      Resized_20210106_185422 by F G, on Flickr
      Red Deer, Alberta, Canada
      I haven't found a flare tool that works on the green coated brake line yet that doesn't make a mess of the coating or slip that is affordable compared to others.
      With that said... Youre really only dealing with 3/16 tube so a higher end specific to one size flare tool might be the best answer.
      Matt
      Instagram: Cst_koon
