    Page 2 of 2 FirstFirst 1 2
    Results 21 to 28 of 28
    1. #21
      Jun 2018
      Alamo, CA USA
      With insufficient wrap on the pulley you can get belt slipping and squealing under load. If it slips you lose your power steering assist which is not good. Track driven cars need maximum belt wrap.
      Systems where the belt just kisses the pulley are not suitable for track driven cars imho. Even the OEMs strive for good belt wrap.
      Makes sense. Now I just need to decide between Drive Junky and Wegner. Between those two, which do you guys feel has the better PS pump? If I can put off buying the Turn One pump for a little bit, that would be helpful. The following are Speedtech's requirements for steering pump:
      ExtReme Power Steering System Requirements
      The Sweet dual power steering rack is a very high quality part. Considering the way Speedtech has spec’d its internals for maximum all round performance and through extensive testing and racing our Sweet equipped test cars we have come up with the following critical requirements to ensure proper function, reliability, and longevity of your power steering system.
      The use of a very high quality power steering pump is required
      • We recommend either Jones Racing or Sweet Manufacturing.
      Both of these pumps are hand built and have extensive internal modifications to increase both performance and longevity over any other pump that we are aware of.
      • Do not use a factory style or spec'ed steering pump.
      MAXIMIM RPM of the steering pump is 5200 RPM
      Please ensure your pullies are sized for this max speed accordingly with max engine RPM. Although individual needs may vary, we generally recommend:
      • 5” crank Pulley
      • 6.5” power steering pulley
      Required Power Steering Pump Specifications
      • 3+ Gallons per minute
      • 1300 psi
      We recommend a series 60 eccentric in the power steering pump.
      You MUST use a quality power steering cooler
      • Minimum of at least 44 sq inches.
      You MUST use a high quality fluid, we recommend
      • Jones full synthetic, or
      • Sweet full synthetic
      Also, which is more easily serviceable with common parts in case something fails in the field?
      Edit: I'm heavily leaning towards the DJ kit. All of the Speedtech cars are using them and it looks like it's everything I need and more.
    2. #22
      Jun 2018
      Alamo, CA USA
      Purchased the Wegner WAK033 yesterday. Solid black everything with the 225 amp alt. The PSC power steering pump is spec'ed at 3.1 gal/min and 1500 psi compared to 1100 psi of the Jones unit on the Drive Junky. I'm sure both are fine, but not a lot of the Speedtech cars were using the Wegner and I like the idea of trying something different to see how it works.
      Thanks everyone for your help.
    3. #23
      Jul 2013
      N. Scottsdale
      How did this accessory drive work for you?
    4. #24
      Sep 2017
      Wegner Automotive no all the way.
      Excellent quality, fit and finish
      Jason
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    5. #25
      Sep 2017
      I might mention mine is a Speedtech equipment car. Not the xtreme but the original pro touring sub up front and torque arm rear.
      Wegner accessories drive
      TANKMASTERJ
      Jasons Toys
      2000 HD Softail
    6. #26
      Jul 2013
      N. Scottsdale
      Has anyone used an accessory drive from CVF? Considering the LS mid mount for a late second gen firebird.
    7. #27
      Nov 2014
      Lake Worth, FL
      Quote Originally Posted by Alponcho View Post
      I have it
    8. #28
      Jul 2013
      N. Scottsdale
      Quote Originally Posted by Camaro68+69 View Post
      I have it
      Any issues with the install, fit in the car, etc?
